Installed LED backup lights - Hemi Truck Club
Old 10-30-2013, 02:37 AM   #1
5.7 Hemi Laramie Longhorn
Silvercreek's Avatar
I replaced the backup light bulbs with LED bulbs that are nice and bright. There's only one issue. The instrument panel indicates that the backup lights are out. Is there something I can do to correct that or am I going to have to put the stock bulbs back in?
"One Small Step for Man, One Giant Leap for RAM Fans."
2013 Laramie Longhorn
US Army Retired - 11B40 1964/'85
Silvercreek is offline   Reply With Quote
Old 10-30-2013, 06:31 AM   #2
You will need to add a resistor to the reverse light wires an led does not have the same load a standard bulb has basically you need to trick it
Measure resistance of old bulb across contacts and new bulb and buy a resistor set(one for each side) that makes up the diff and light should go out
Old 10-30-2013, 07:01 AM   #3
That's odd because one of the guys over on another RAM forum said it was a Plug-N-Play installation.
In either case the message in the instrument panel, "Backup Bulb Out" must have made an automatic correction because it didn't come on this morning.
Old 10-30-2013, 07:57 AM   #4
The bulbs are yes but the self diagnostic the truck has sees an issue
Old 10-30-2013, 11:11 AM   #5
Question
I can only add that the RECON LED tail lights and their LED backup replacement bulbs work perfectly with no alterations in my '05. You just need to make certain that they are plugged-in the correct way because they are polarity sensitive .
Old 11-03-2013, 01:19 AM   #6
The bulbs are yes but the self diagnostic the truck has sees an issue.
You are correct. The failure cold has shown its ugly head again. I've removed the LED's and re-installed the stock bulbs. I guess it's limited what can be done to these trucks without some kind of modification to the system.
Old 12-19-2013, 06:51 PM   #7
Gold-Member
kcd1369's Avatar
Got my Superbrightleds in
Got my new LED backup lights installed today as well as my 3rd brake light.
Very happy with the backup lights. Not impressed with the brake light.
These are the 3157-W26-CBT in white. back up bulbs.
The brake light is WLED-R9-CBT in red.
No codes since these come white the resistor already installed in them.
The still shots on the second pic. it has one LED and one reg. bulb
Old 12-19-2013, 06:56 PM   #8
KEN
BAMA-HEMI's Avatar
2012 Ram 1500 Laramie Sport Crew Cab 5.7L Hemi
_
BAMA-HEMI is offline   Reply With Quote
Old 12-19-2013, 07:01 PM   #9
Steve
deke6520's Avatar
2014 Ram 1500 Sport QC 4X4
Hemi, Granite Crystal Metallic, 3.92, Magnaflow True Dual Catback Exhaust, Diablosport Intune with Jay Greene's 91 Custom Tune, 87mm Ported Throttle Body, S&B Intake, Mopar Side Steps, Bakflip F1 Tonneau Cover, BT Catch Can, Gatorback Hemi Mud Flaps, Tinted Tails and Third Brake Light with Lamin-X, 6K HID's, 40" Diode Dynamics Light Bar, Dual 3" LED Pods in fogs, 305/55/20 Mikey Thompson ATZ P3
deke6520 is offline   Reply With Quote
Old 12-19-2013, 07:48 PM   #10
Gold-Member
kcd1369's Avatar
One more with the lights out. Hard to tell, these things are so bright.
