high beams and fog lights - Hemi Truck Club
Old 11-09-2009, 10:54 AM   #1
i know there's a relay out there somewhere that allows vehicles with the 4 headlight set-up to keep the low beams on while the high beams are on, but does anyone know if there is a relay to keep our fog lights on while our high beams are on? if so, where would i find it? or do you know how i can go about wiring it up myself?
thanks in advance!
txbubba is offline   Reply With Quote
Old 11-09-2009, 03:14 PM   #2
afteamroper's Avatar
I am sure if you got a wireing diagram you could figure out how to bybass what ever controls the fogs so that they could stay on all the time or you could rewire them to a switch in the cab so that you could control when they are on and off
afteamroper is offline   Reply With Quote
Old 11-09-2009, 05:18 PM   #3
&quotRANCHER&quot
It was an easy fix on the 02 thru 05. Newer trucks are a lot different. I'll try to make a few calls tomorrow to see if it can be done some way other than through the computer.
Old 11-09-2009, 10:33 PM   #4
madcat's Avatar
quoter you could rewire them to a switch in the cab so that you could control when they are on and off
That would be the EASIEST way to do it... be sure to use an "ACC" circuit.
Here is a picture on how to do the jumper trick... only good for 02-05 Rams.
Old 11-09-2009, 10:37 PM   #5
quote:I am sure if you got a wireing diagram you could figure out how to bybass what ever controls the fogs so that they could stay on all the time or you could rewire them to a switch in the cab so that you could control when they are on and off
________________________________________________
This is what I would do; run heavy gauge wire from the fogs to a 30 amp relay, use inline fuse at battery connection and use heavy duty dash mounted rocker switch with a pilot lamp - then turn on any way you wish.
Old 11-10-2009, 10:01 AM   #6
BergsBlueHemi's Avatar
Does anyone have anymore info on running the high and low beams on together? I sometimes have just barely pulled light switch lever and like how bright the lights look with both on. I just didn't know if that was possible? Thanks guys!
BergsBlueHemi is offline   Reply With Quote
Old 11-10-2009, 03:51 PM   #7
Hemiguy05's Avatar
The only trouble I see with both on would be the heat may melt the headligth lense. Ive seen it done on some after market headlights on other models. There is a guy on ebay that sells a setup to run the fogs and high beams at the same time.
Hemiguy05 is offline   Reply With Quote
Old 11-11-2009, 10:59 PM   #8
mksugls's Avatar
The guy who owned my truck before me went to the trouble of having the dealership install the fog lights, but put in a seperate switch. It's not hooked up to an ACC circuit either. Weird to go to some of the trouble and finish rough. Looks good and it's a clean job though. I like having both on at the same time. Good Luck!!!
mksugls is offline   Reply With Quote
Old 11-12-2009, 10:06 AM   #9
i'm thinking i might just add a toggle switch inline, but i don't know that i feel like doing that much work. thanks for the help guys.
Old 11-21-2009, 03:19 PM   #10
megacab's Avatar
Why mess with the low power fog lights ??
Buy a good set of driving lights with the relay kit and realy get some light !!
