12-07-2008, 04:31 PM
#5
Help !! Brake lights staying on solid
quote:Originally posted by madcat:
quote:brake light switch is stuck...
this is the only common place in the system that all three brake lights receive power/signal from. You took it out, they turned off, you re-installed it, they came back on..
I have it removed and the plunger still moves in and out freely so the contacts must be fried put it back in same result ..Then I read the huge print right on the side of the switch ..DO NOT REINSTALL so i guess im off to get a new one tomorrow if that dosent work Ill check the wiring pretty sure its the switch though all other lighting systems are good... thanks for all your responces
