fog lights - Hemi Truck Club
Old 09-29-2016, 08:44 AM   #1
fog lights
I hope some one can help, I just installed a new Bull Bar with fog Lights and can not figure out were to hook up the power wire. Thy said to hook to battery but all I see is a two post one saying 120 V and the other 140 V . Is there a spare tap in the fuse box. Any suggestion would help. Thank You
azkid is offline   Reply With Quote
Old 09-29-2016, 01:01 PM   #2
What year truck is it?
Old 09-29-2016, 04:27 PM   #3
azkid
Old 09-29-2016, 05:58 PM   #4
Queen Kima - Whemi BOD
Mrs.Studmuffin's Avatar
Old 09-30-2016, 07:38 AM   #5
2014 Hemi 1500 SLT, 5.7L
Old 09-30-2016, 07:43 AM   #6
OH! I found a fuse in the fuse box under the hood (F60) for the under hood light but no light under hood can I use that fuse, 15Amp?
Old 09-30-2016, 09:15 AM   #7
There's a terminal with a round cap on top of it just forward of the battery corner close to the IPM. Figure out what your current draw is for the lights and use a inline fuse greater than the total draw. Use a automotive 12v relay rated for the draw. Then use a switch to control the relay to power the lights.
Note: I see your truck is a 2014, so the terminal may not be there.
Old 09-30-2016, 09:20 AM   #8
Are you wiring these to factory switch or a toggle switch?
Old 09-30-2016, 10:17 AM   #9
Agree - use a heavy duty switch and heavy duty relay - wire them independently of your system so you can turn them on and off when YOU want to...
Old 09-30-2016, 01:56 PM   #10
And I would recommend using ignition on power source for the switch. This way you can leave the switch in the on position and the fogs will turn off when you turn the key off.
