Dim dash lights. - Hemi Truck Club
Old 01-20-2017, 03:28 PM   #1
Unhappy Dim dash lights.
Dash lights will dim at certain times and return to normal also back up camera will lag for a short time before functioning. Any advice would be great. Thanks in advance.
waxman is offline   Reply With Quote
Old 01-20-2017, 03:41 PM   #2
Matt
MANual_puller's Avatar
Do they happen at the same time or are we looking at two different problems?
Old 01-20-2017, 03:50 PM   #3
Same problem.
Old 01-20-2017, 05:24 PM   #4
CavRam's Avatar
Our trucks have an amazing amount of electronics. Start with the basics. Ensure grounding points under the dash are clean/secure and ensure your battery and charging system is healthy. You will be amazed at the weird symptoms a sub-par battery will create.
2014 Ram 1500 Express
Old 01-21-2017, 04:12 AM   #5
Yes like stated make sure batt and alternator are working/charging solid. If they are good double check the grounds you can see in the engine bay from battery to frame they sometimes corrode. If they are good then it's likely something inside and the real diagnosis needs to start
Old 01-21-2017, 07:52 AM   #6
Thanks for the info I'll check the electrical system.
