Clouded Lenses - Hemi Truck Club
Old 12-31-2012, 04:26 PM   #1
hemiram32's Avatar
Hey folks, have noticed my headlight lenses are getting pretty cloudy,not putting out anywhere near the light they used to. I have noticed several different kits to polish and clean them up, just wondering if anyone has any experience with them. I guess they would be worth a try,but didn't know if the haze would be just on the surface or all through them. Thinking of just replacing them. Wish you could get glass lenses like my fog lights,still bright as ever.
Sold--2004 1500 HEMI SLT Offroad RC/SB, AWD, Airaid MIT, K&N Drop-In Filter,Superchips, Headers,Dynomax Super Turbos,2.5" front lift,2" rear lift, 35x12.50x17's
hemiram32 is offline   Reply With Quote
Old 12-31-2012, 05:34 PM   #2
5.7 liters of freedom's Avatar
The foginess is from oxidation of the lens cover. Anyone of the kits should take care of it as long as it is done right. but the yellowing is only on the outside. I haven't done it personally, but my work does it and it turns out great, they look brand new when done
Dreams Live On Forever, Only People Die In Shame.
Westin nerf bars, BFG All-Terrain 285/70R17, Truxport tonneau cover, AVS Ventshades, AFE CAI, Recon LED Tailights and 3rd Brake light, OEM Foglight upgrade, Best mod of all-----My lead foot
5.7 liters of freedom is offline   Reply With Quote
Old 12-31-2012, 06:19 PM   #3
I bought one of the kits available at Advance Auto and polished my daughter's headlights. Turned out good, then cleaned up my 03 lens. Just follow the instructions. I think the kit was around $30.
Old 12-31-2012, 06:26 PM   #4
If the kits are done right and the directions are followed the lens can be cleared almost 80-90% and will last for around a year and then start to fog again the main reason the lenses do that is auto car wash wax on the lens and the headlights burn it in fogging the lens a neat little trick for a car show is auto trans fluid wash your vehicle then run the lens with ATF and it will be crystal clear and last about a week then disappear and of again my truck in the picture here had extremely foggy lens and this is after I did one side 90% better very good
Old 01-01-2013, 07:51 AM   #5
TooCool's Avatar
My daughter bought some stuff called white diamond. It's an aluminum polish that work's on headlight plastic len's. Her lens' on her mazda were very, very bad. For as bad as they were it helped quite a bit with little rubbing. This might be a good choice if there not to bad. Also seen some result's of the wipe new stuff. Guy did a little sanding of the len's, cleaned it up after then aplied the wipe new. The light's looked like brand new. The stuff has to cure for 24hrs. so it's more of a permant fix. I've been wanting to get some to try on the black plastic trim to see how it work's and hold's up.
Old 01-01-2013, 02:05 PM   #6
hemiram32's Avatar
Thanks guys. Didn't know if they were all they were cracked up to be or just a gimmick. Saw a commercial for the wipe new, if it works half as good as they make it out, would be some good stuff. One my buddies said he used chrome polish on his wifes car and worked pretty good. I'm used to the old school sealed beam lights,new lenses every time you changes lights. Thanks again.
Old 01-01-2013, 03:40 PM   #7
Retired BOD - Doug
RANCHER's Avatar
Stay away from the "As seen on TV" stuff. I tried some on my rain gauge and it did nothing. Looks like the same kind of plastic. Never kept a truck long enough to have an issue and it stays in the garage a lot too.
Old 01-10-2013, 09:31 AM   #8
dodhem06's Avatar
2006 1500 Quad Cab "Lone Star" Edition.
As a courtesy to the other drivers, this is what a HEMI looks like from the front.
dodhem06 is offline   Reply With Quote
Old 11-24-2013, 01:59 PM   #9
try toothpaste before you go out and spend all that money
papanogo1 is offline   Reply With Quote
Old 11-24-2013, 04:39 PM   #10
Board of Directors-Bill
arocketman's Avatar
Good option. Light abrasive. I know it works good on Jewelry.
papanogo 1, Welcome to the club.
Post up in the new member post and tell us a little about your HEMI.
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
