Would it cause problems? - Hemi Truck Club
Old 03-17-2008, 12:26 PM   #1
Jakeace1's Avatar
Would it cause a problem for the truck or problem with tire sizes if I got 22x9 SRT-10 rims for the front of my truck and the 22x10 SRT-10 rims for the rear?
Jakeace1 is offline   Reply With Quote
Old 03-17-2008, 05:42 PM   #2
UPSTATENYHARDCOREHEMI
shouldn't cause any problems aslong as you keep the over all tire diameter the same.
Old 03-17-2008, 08:39 PM   #3
The Original Bee
HemiSuperBee's Avatar
If you plan on getting 2 different tire sizes, you won't be able to rotate the tires properly, front to back.
Old 03-17-2008, 11:39 PM   #4
Just curious why you want to use the 9's on the front?
I've been running the SRT 22 x 10's with Pirelli 305/45/22 tires on my 2005 Ram 1500 2WD at stock suspension height with no problems for over a year now.
Old 03-18-2008, 12:13 AM   #5
Jakeace1's Avatar
I was thinking that I could go with the 305/45-22 on the front and 325/40-22 on the rear with the thought that it would give me more traction when taking off. I was thinking also that the 325's would be to wide on the front. I also do not have a FlashPaq so I was kinda hoping that the tires would match up with the diameter of my stock wheels which are 275/60-20. I guess if all else fails I could stay with the stock rims and go with 285/55-20 for the front and 325/50-20 for the rear. I really do not know what would be best but I know that traction is a must and with a bigger patch of tire on the road it seems to mean that it would have better traction.
Old 03-18-2008, 12:37 AM   #6
Sounds like just a personal choice - whatever you like the best; the 305/45/22's are going to be as close to your 275/60/20's as possible - that is what mine originally came with - then I went to the 45's.
I'm running a 3815 SuperChips, CAI & Exhaust and the 22's still hook-up and work just fine.
Good Luck!
Old 03-18-2008, 12:53 AM   #7
Try this chart:
http://www.wheelcitystl.com/tires/chart.htm
