Wheel well lines - Hemi Truck Club
Old 04-25-2016, 02:29 PM   #1
hemimike06's Avatar
Wheel well lines
Where can I get the rear wheel well liners for a 2004 Dodge Ram. Looking for the best price. Years ago I got them for a 2006 a got them from a dealer in Ohio
Thanks.
Old 04-25-2016, 05:04 PM   #2
Lightbulb
MOPAR OEM are probably the only ones that will fit correctly and may be the only ones available anyway. Make sure you have proper clearances if you are using a very wide tire/wheel combination or if you have suspension modifications that might get in the way or rub.
Old 04-25-2016, 07:55 PM   #3
CavRam's Avatar
Take snow chain use into consideration also (your sig says PA).
I had wider tires on my stock 04 rims and there was no way I could use my snow chains unless I took off the liners.
2014 Ram 1500 Express
Old 04-25-2016, 10:12 PM   #4
I purchased mine from Jegs and they are Mopar OEM liners I installed on my 07' ram.
Old 04-26-2016, 04:54 AM   #5
Good find..
Old 04-26-2016, 10:12 AM   #6
I like those - just wish they would work with the SRT10 - 22's .
Old 04-26-2016, 11:00 AM   #7
Tyler
TYSENUS's Avatar
82207367AB this is the kit you are looking for. It comes with both sides and the hardware to install them.
Mods:
Old 04-26-2016, 11:11 AM   #8
Question
Are you saying this kit will work with the SRT10 - 22 wheels and 305/45/22 tires? I found out the liners would not work without rubbing on a 2005 SRT10 Ram with this tire/wheel setup.
Thanks
Old 04-26-2016, 11:23 AM   #9
Tyler
TYSENUS's Avatar
It tells me that is not for use on an SRT10, sorry I missed the part where you said you had those wheels. There is nothing available specifically for that model though you should be able to easily modify it to work.
Mods:
