vibration in steering wheel when in 4hi - Page 2 - Hemi Truck Club
Old 01-01-2008, 06:22 PM   #11
03hemiman's Avatar
my problem was fixed when i had them lower the torsion bars i had too much of a angle on the front axle shaft after my bars were cranked
03hemiman is offline   Reply With Quote
Old 01-03-2008, 05:59 PM   #12
Dreamin\ HEMI
35" tires, 6" Suspension lift Kit, maxed out torsion bars....had to replace the front drive shaft after 70K miles WITH THE LIFT! Bought a front shaft for $70 delivered, 5 minutes to swap it out, done.....However I've NEVER had any weird vibration before...just a slight clunking sound that was the joints wearing out eventually. Most likely doe to the heavy angle on that shaft. Oh well, $70 is worth it to me every so often.
Old 03-27-2008, 10:44 PM   #13
I actually get that vibration in my truck and it is bone stock. I did have the tires balanced the other day and the vibration seemed to get worse as the tires wore though.
07sport is offline   Reply With Quote
Old 03-28-2008, 07:40 PM   #14
CentralTexHemi's Avatar
Welcome to HTC!!
Have them roadforce balanced call one of these places http://www.gsp9700.com/pub/search/FindLocations.cfm
and make sure you tell them exactly what size tires you have and ask how long their tech has been doing it, do not accept anything over 20 pounds roadforced if they are they are bad tires
Old 03-30-2008, 11:28 AM   #15
The Original Bee
HemiSuperBee's Avatar
quote:anything over 20 pounds roadforced if they are they are bad tires
Not necessarily. For a (P)tire anything under 28lbs. is acceptable, for (LT)tire anything under 32or34lbs.
The balancer tells the tech if the tire and wheel assy can be matched or not. If not, the tire will have to be installed on a different rim, and the assy. will have to be checked again. It will also tell you if you have a bad rim.
This can be expensive moving a tire from rim to rim but well worth it to solve balancing issues.
