tyre size - Hemi Truck Club
Old 11-25-2011, 05:43 PM   #1
tui
tui's Avatar
reading the factory label on the door of the rumbleBee it tells me tyre pressure but states the factory tyre size as 17 inch but my factory wheels are 20 inch. what gives?
Old 11-25-2011, 05:43 PM   #2
tui
tui's Avatar
Old 11-25-2011, 06:02 PM   #3
BTeves's Avatar
What kind of psi does it say?
Old 11-25-2011, 06:16 PM   #4
BTeves's Avatar
Normally as long as it ain't feeding you some HD psi you're ok, in the 35 range I assume?
Old 11-25-2011, 07:07 PM   #5
tui
tui's Avatar
It says the 17's should have 36 psi which is what i have been doing until i realised my truck had 20's.
I've got my sock on the mantlepiece and a bit of cake for Santa, lets hope i can stay awake for the big guy in red. my xmas wish is the winning numbers for the 20 mill lotto draw tonight.
Old 11-26-2011, 04:17 AM   #6
Retired BOD - Doug
RANCHER's Avatar
I think I ran 35 psi in mine.
Old 11-26-2011, 05:16 AM   #7
Mr. Freeze
VA4MEDS's Avatar
Just look at the sidewall of the tire and don't exceed the max by more than 1-2 lbs.
You can adjust for a smother ride by decreasing a few pounds.
I run 34 in mine and it does fine.
The door label is for the tires installed at the factory only. If you put LTs on for example, you might have a max air of 60-85 lbs. Or a cheap tire might only max 32 lbs.
Old 11-26-2011, 07:26 AM   #8
askibum02's Avatar
You spelled tire wrong.
Brett
Old 11-26-2011, 03:12 PM   #9
tui
tui's Avatar
LOL Bret. Its how us colonials spell tyre down this part of the world. We also have a U in colour and honour. Proper english old chap.
Old 11-26-2011, 03:14 PM   #10
tui
tui's Avatar
I'm sorry, I forgot. Thanks for the info friends.
