Smaller Wheels - Hemi Truck Club
Old 10-01-2012, 11:45 AM   #1
FLRamSport's Avatar
I am about to get some new wheels and I am thinking of going with a smaller tire(275/45/20 Goodyear Eagle GT 2) This tire has a 3.25" difference in diameter from the stock 275/60s. Think it will be alright? Im not tire expert here...
2012 Sport QC, 2/4 McG Deluxe Drop Kit, AEM Brute Force CAI, Custom Engine Cover, Tinted Tail/3rd Break, Black Headlights
FLRamSport is offline   Reply With Quote
Old 10-01-2012, 11:45 AM   #2
FLRamSport's Avatar
Old 10-01-2012, 02:52 PM   #3
If you are running 4.10 or 4.56 gears and dd it don't do it you rpm will be high if you have 3.92 or lower it would be ok for dd we run 28" slicks at the track and 108 at almost 6800 rpm in third so I would imagine with gear rpm would be up there stocks gears is bearable I would say
Old 10-01-2012, 11:51 PM   #4
I run 28" tires with a 4:10 gear at 2100 @ 65mph. Not a problem...
Old 10-02-2012, 11:16 AM   #5
Birdshot's Avatar
I suspect you'll like it. The drop in size (diameter) will make it feel like you put a set of gears in it.
Old 10-29-2013, 03:00 PM   #6
hmmm, I also switched to a 17" (265/70R17) winter tire from a stock 275/60R20 all season. Not sure what my gearing is but the overall difference in height is about 2" lower. Is my speedometer & odometer going to be out?
10Canuck is offline   Reply With Quote
Old 10-29-2013, 03:20 PM   #7
Lightbulb
______________________________________
Yes your readout will be off; somewhere here on HTC a long time ago there was a great post showing a calculator that would immediately give you a reading for just about every tire & wheel diameter combination available - but I can't find it at the moment - maybe one of our techie guru's can retrieve it for you .
Old 10-29-2013, 05:35 PM   #8
BikerEric's Avatar
I have been using this one from Tacoma world...
Tire Size Calculator - Compare Tire Sizes
It is said that some suffer from insanity. I, however, choose to enjoy it!
BikerEric is offline   Reply With Quote
Old 10-29-2013, 06:45 PM   #9
Smaller tires will fit better with the overall look of your lowered truck. You should check out some lowered trucks for their tire size.
Old 10-29-2013, 08:22 PM   #10
great calculator. Thanks BikerEric. Thanks too Ghost03hemi.
