replacing wheel assembly - Hemi Truck Club
Old 10-01-2012, 04:50 PM   #1
2004 quadcab, 2 wheel drive. LF wheel bearing bad. Need to know how to replace wheel assembly. Thanks. Greg in sw Ohio.
Flash is offline   Reply With Quote
Old 10-01-2012, 04:50 PM   #2
Old 10-01-2012, 05:03 PM   #3
If replacing hub l/f jack up support truck with stand remove wheel set aside insert a screwdriver into caliper opening and pry back a little making caliper removal easier turn wheel all the way to right and removal caliper bracket bolts leaving caliper attached to bracket and support out off way remove rotor (may be a little stuck) disconnect wheel speed sensor from fender if applicable then remove 3 hub bolts and remove hub from truck install new hub and torque bolts then reverse removal procedure
Old 10-01-2012, 07:27 PM   #4
Old 10-02-2012, 05:07 AM   #5
HTC.com Titan Killer Club
Member # 17
Old 10-11-2012, 08:47 AM   #6
JustHemi's Avatar
If only doing the procedure was as quick as reading that.... Although, it is pretty easy...lol.
Amsoil Dealer (Greenwood, IN)
www.lubedealer.com/indyoilguy
Ph#: 317-383-6061
Many mods to come....hehehe.
Old 10-19-2012, 07:03 PM   #7
OldBaldie's Avatar
One additional note: your ABS light may come on, due to your replacing the hub. Not a problem, as the light should go out after the wheels are moving and the signals all sync up; else you forgot to hook up the sensor.
Make sure that your walk talks, louder than your talk talks.. Jesus rules!
When you put the gun in the holster, put the ego in the gun safe!
I view Nitrous like that hot chick with an STD; you want to hit it, but you're afraid of the consequences....
OldBaldie is offline   Reply With Quote
Old 10-20-2012, 05:10 AM   #8
Mr. Freeze
VA4MEDS's Avatar
That would be my main downfall...I always foeget something...
Old 10-20-2012, 07:02 AM   #9
askibum02's Avatar
Me too.
Brett
