rear wheel bearing? - Hemi Truck Club
Old 09-19-2015, 07:44 AM   #1
Bama's Avatar
rear wheel bearing?
4 months ago replaced the frnt L wheel WHB, last week the right ( money issues), Now the right rear wheel has the whump whump sound. Jacked it & the wheel has play. Its an 06 Q 4x4 with 82k miles. Is this normal? Never done a rear wheel before, I appreciate any advice!
Old 09-19-2015, 08:33 AM   #2
It's not that simple buddy. You have to pull the diff cover and remove the brakes and the axke on that side to get to the axke bearing in the diff tube. You will need a slide puller or old schools way remove left side and use a really long bar thru diff assembly to drive opposite out.
Old 09-20-2015, 06:03 AM   #3
boedacres's Avatar
the sound might be a tire noise. Never had a bearing making a whump whump sound. most of the time the growl. Swap tires to the front and see if the noise moves with them?
Old 09-20-2015, 07:24 AM   #4
Bama's Avatar
will do, thanks guys
Old 09-20-2015, 10:23 AM   #5
Is the axle leaking? Usually a bad bearing will take out the seal.
Old 09-20-2015, 11:05 AM   #6
Bama's Avatar
Dry as a dessert bone Redtrk. Just remembered , spun out in the snow & popped a curb on said right side.not hard just thumped. If that caused this problem then, dodge should have never made a 4x4. could i have possibly warp an axle?
Old 09-20-2015, 11:11 AM   #7
Sliding into a curb is a good way to bend a axle. Easy to check. Put a floor jack under the pumpkin and lift the wheels off the ground. Start her up and spin the rear wheels and see if the spin true or not.
Old 09-20-2015, 01:50 PM   #8
Bama's Avatar
deff will give that a try.HTC rules!!
Old 09-24-2015, 02:48 PM   #9
Enormous Member
Hugh Jassole's Avatar
sounds like a bent axle to me, sorry
My other truck is an R/T
Old 10-10-2015, 08:50 AM   #10
Bama's Avatar
Thank's for the comments Guy's. My computer is old and don't work most of the time. Its hard to get online. Is there any video of rear bearing replacement for my truck?
