Heads up..rear brake pads..no squeeker - Hemi Truck Club
Old 02-25-2008, 10:13 AM   #1
5point7 hemi's Avatar
I found this out this weekend after hearing a grinding noise on my 04 1500 while I was braking.
Some brake pads come with a "brake warning sensor" that will emit a squealing noise when the pads are worn to a point where they should be changed. The front pads have them, but the rear pads do not have them.
I have always assumed the had them on all 4.
Anyhow, after 96,000 miles, I finally wore my rear pads out.
I had to remove the rotors and have them turned to get the groove fixed.
It is all good now, but I was pissed at the place that did my yearly state inspection for not noticing that the pads were almost shot.
Then again, I guess I should have checked them myself...
I hope others read this and don't make the same mistake.
5point7 hemi is offline   Reply With Quote
Old 02-25-2008, 01:10 PM   #2
TheBoss's Avatar
Good reminder.
Old 02-25-2008, 04:10 PM   #3
UsmcMan96's Avatar
Old 02-25-2008, 04:56 PM   #4
I know in PA when they do inspection, they make a note on the sheet of what all the brakes and tires are at at the time of inspection. Rear brakes last A LOT longer than fronts because most of the stopping power is in the front. 96K is good though.
Old 02-25-2008, 05:54 PM   #5
Strange as it may sound, I've got 72K on my original pads, and rotors.
Old 02-25-2008, 06:21 PM   #6
CherryRedHemi's Avatar
quote:I hope others read this and don't make the same mistake
Thanks for the heads up.
quote: Strange as it may sound, I've got 72K on my original pads, and rotors
I was up around 80k on mine, and needed dancing lessons trying to bring it to a quick stop.
CherryRedHemi is offline   Reply With Quote
Old 02-26-2008, 08:25 AM   #7
Mid-Tenn-Hemi's Avatar
quote:Strange as it may sound, I've got 72K on my original pads, and rotors
I've got 89,000 on the original pads and rotors. The front need to be changed SOON. I am going with the NAPA high performance rotors and pads all the way around.
Mid-Tenn-Hemi is offline   Reply With Quote
Old 02-27-2008, 12:31 AM   #8
semo03hemiram
Glad you got it fixed. Inspection stations just look for wear on the rotors, most don't pay attention to the pads....
Old 02-27-2008, 08:54 PM   #9
sppb's Avatar
don't you stop at the red lights?
Old 02-29-2008, 11:24 AM   #10
Football_Bill's Avatar
I bought my truck used, but at 25000 the dealership said the fronts were at 15%, backs still at 80%. I want to do the slotted rotors and some good pads, will I need to get new calipers also?
Football_Bill is offline   Reply With Quote
