Difference between 275/60/R20,305/55/20 & 35 12.50-20 - Hemi Truck Club
Like Tree1Likes
Old 12-22-2015, 10:07 AM   #1
I have a 04 1500 5.7 4wd Slt Quad Cab and I was wondering what size tire I should get next time around, the truck has New Shocks and bushings not really looking to do a lift kit at this time. For the most part the truck sits kinda level slight rake to the front. Thanks
P.S Leaning toward BFG or Nitto.
Old 12-22-2015, 10:25 AM   #2
Tyler
TYSENUS's Avatar
If you are not lifting the truck then either the 275 or 305 will work. The 275/60r20 is 33" tall, 10.8" wide. The 305/55r20 is 33.2" tall, 12" wide. You will not be able to get the 35X12.50s to work without at least a leveling kit in the front and even then it would depend on the offset of the wheels that you use.
Mods:
Old 12-22-2015, 12:04 PM   #3
So I can use the 305/55r20 on stock rims with no level and no spacer?
Old 12-22-2015, 01:27 PM   #4
Lightbulb
If you 'do' decide to change wheels now or in the future the 305/45/22 is about as close as you can get in overall diameter to the original 275/60/20 .
PS: You will need a 10" wide wheel or at least a 9.5" to step up to the 22's.
Old 12-22-2015, 01:33 PM   #5
I don't want to change rims at this point.
Old 12-22-2015, 03:24 PM   #6
Tyler
TYSENUS's Avatar
You sure can. I did it years ago with a 2wd and no problems.
Mods:
Old 12-23-2015, 02:13 PM   #7
LowerThatRam's Avatar
https://tiresize.com/calculator/
is a good site to give similar sizes or to figure out how it will effect the OD.
LowerThatRam is offline   Reply With Quote
Old 12-23-2015, 07:45 PM   #8
I am just looking for a tire that will look nice on the truck, Wish I could see different sizes in person.
Old 12-23-2015, 10:07 PM   #9
CavRam's Avatar
This is my old 2WD 04 with Falken ZX 305-55-20 0n stock rims. No issues with clearance.
2014 Ram 1500 Express
Old 12-23-2015, 11:53 PM   #10
