Caster/camber alignment - Hemi Truck Club
Old 04-16-2014, 08:44 AM   #1
Truck of the year 2014
Belgiquebasterd's Avatar
I've got my entire front end on my 2003 2x4 hemi apart and when I bolt it together I'll take it to a shop to get it aligned. I read in the manual that caster/camber is adjusted by moving the upper A arm in the slots of the frame. In the manual it says to use a special mopar tool to move the A arm back and forth in the slots. Is this tool necessary or can it be done with a crowbar or something else?
I'm from Belgium, not a lot of trucks here and alignment shops don't really have experience with them so just trying to find out some details before I go.
Old 04-16-2014, 10:05 AM   #2
boedacres's Avatar
It's a lot easer with the correct tool but it can be done.
Old 04-16-2014, 10:19 AM   #3
How does the tool actually work? Any pictures of it in action?
Old 04-16-2014, 12:35 PM   #4
Gold-Member
kcd1369's Avatar
Old 04-16-2014, 02:09 PM   #5
I have adjustment kits installed on Red. These are non concentric lobes that can be adjusted using a wrench. They make the alignment easier but are not required.
Old 04-16-2014, 02:17 PM   #6
That's basically just a giant washer with a hole drilled out of the centre? I could easily make that myself, thanks for the idea! Any chance of some rough measurements as to what diameter the washer is?
Old 04-16-2014, 02:26 PM   #7
Nevermind, just found em on ebay for 50$ shipping and taxes to Belgium included, not worth the hassle making them myself for that price, so ordered a set.
Old 04-16-2014, 02:38 PM   #8
Christof, oddly it measures just over 2 inches. (2.030). Notice there is a square hole punched in it for a 3/8 drive to turn it.
Old 04-16-2014, 02:45 PM   #9
If I remember right 1 kit is for only one side. You will need two kits for both wheels.
Old 04-16-2014, 04:20 PM   #10
Kits make it nice for sure. But not required at all If you loosen the bolts up you can push/pull the arm around fairly easily. Do it all the time at work.
