Brake locked up. What do you guys recommend. - Hemi Truck Club
Like Tree3Likes
  • 2 Post By Redtruck-VA
  • 1 Post By 3rdstrike
Old 03-14-2020, 12:15 PM   #1
Ariel
RAM4's Avatar
I was driving home today when out of no where the truck pulled heavily to the right. When i got to the next light i saw a bit of smoke coming from the front right wheel. I made it home and checked the wheel temp and it was way hotter than the others. Im pretty sure that wheels caliper locked up. What do you guys think?
Old 03-14-2020, 12:54 PM   #2
That sounds like a typical caliper failure. Either the caliper isn't releasing or the nrake line has ruptured internally and id holding pressure. Quick test is to bleed the brake and see if it releases.
SUPER BEE and ric3xrt like this.
Old 03-14-2020, 02:37 PM   #3
Ariel
RAM4's Avatar
Thanks for the tip. Ill try that. 👍🏼
Old Yesterday, 07:21 PM   #4
3rdstrike's Avatar
Check to make sure it is still properly installed also. We were in the Power Tour with our Ram (its one of the ones in the header above - the one with the roll bar)...and our caliper bolt fell out. I had no way to replace it at the time, so I removed the caliper, used a pair of vise grips to crimp the brake line, and went on to the hotel. Fixed it the next day when I could get a replacement bolt....
SUPER BEE likes this.
3rdstrike is offline   Reply With Quote
