Bad vibes - Hemi Truck Club
Old 10-13-2014, 06:12 PM   #1
Farrrrrr East Coast
NewfieBullet's Avatar
Angry Bad vibes
so after having my tires balanced twice, this time they were bang on ,on the machine, watched them do them, no cupping. anyway i have a bad shake around 60-70 mph...like an unbalanced tire, i always blamed it on the lift cause i knew my pinion angle was off, after i removed the lift its much better, only noticeable at those speeds vs all the time. so i had the tires rebalanced just to try it and no luck....i know my rear rotors are warped a bit and im thinking the lift may have done a number on my u joints...could this be the cause of my shaking? or should i just wait a while until i replace my tires to see if they really are the culprit?
Old 10-13-2014, 06:32 PM   #2
Can you put on a spare set of tires? I chased a vibration around and around and it was the tires. They balanced, but had hard spots that made them ride horrible.
Old 10-13-2014, 07:03 PM   #3
Matt
MANual_puller's Avatar
My truck has eaten 3 u-joints and they only get worse with time, nothing makes them better except new ones. They'll have a much faster vibration than a tire or rotor would cause and usually only vibrate either on or off the gas. Doesn't sound like that's the culprit.....
Old 10-13-2014, 07:15 PM   #4
If it walks like a duck and quacks like a duck then it must be a duck. I'm calling bad tire(s).
Old 10-14-2014, 08:20 AM   #5
Matt
Quack.
Old 10-14-2014, 08:52 AM   #6
Farrrrrr East Coast
Well ill have to wait for my new tires to go on to be sure...on or off the gas dosentt make a difference
Old 10-14-2014, 09:08 AM   #7
Originally Posted by MANual_puller View Post
Quack.
Me too
You might be surprised just 'how-far-out' many tires are ...and it seems the bigger and heavier they get - the bigger the problem .
My 2 cents,
Old 10-23-2014, 06:19 PM   #8
Farrrrrr East Coast
ya they arnt huge but they are 35 inch mt tires at about 70 lbs each, vs the replacements 45
Old 10-23-2014, 06:36 PM   #9
Poorboy6.4's Avatar
I would say its the tires had a brand new set made the truck miserable to drive had them changed out no more issues
Poorboy6.4 is offline   Reply With Quote
