Anyone have experience with Satisified Pads? - Hemi Truck Club
Old 03-11-2008, 11:19 PM   #1
BigART's Avatar
I just turned 80K last night and the rears just started squeeling. I have EBC Green's on the front and love them, but not sure it is really needed for the rear.
Looking for some suggestions.
Old 03-11-2008, 11:35 PM   #2
chefred112's Avatar
...how about Scott's old pads...still have plenty left...LOL
Old 03-12-2008, 05:19 AM   #3
BigART's Avatar
That's a thought.
When you change pads you should turn your rotors. And putting on hold pads is bad juju I'm told.
I need to find a local place to turn slotted rotors is my problem right now.
Old 03-12-2008, 08:49 AM   #4
Don't know about Satisfied Pads, but Rancher can tell ya about Depends.
Old 03-12-2008, 10:46 AM   #5
chefred112's Avatar
quote:Originally posted by BigART:
That's a thought.
lol...i'm only kidding with you since that last convo we had about 2nd hand brakes/rotors..
Old 03-14-2008, 12:18 AM   #6
BigART's Avatar
Well I thought it was the rear brakes, but I soon realized it was the front.
The front drivers side, for the 2nd time, was much more foregone then the passenger. I'm wondering if I have some sort of equalization problem in the brake system???
I bought the Satisfied Pro Ceramin front and back. I got the front done after braking one of the caliper bolts. I will do the rear tomorrow.
So far they seem pretty nice. They don't have the groove down the middle like other performance pads and the don't have the warning indicator on them. So I will just keep a closer eye on them when swapping tires at the track.
Old 03-18-2008, 11:21 PM   #7
BigART's Avatar
Here's an update...
The don't grab right away like the EBC's, but they're better then factory. I would have to say they're in between performance wise. Time will tell how long these last.
Old 03-19-2008, 02:04 PM   #8
Any place that cuts brake rotors should able able to cut the slotted ones. They just can't cut as much on each pass like they would a standard rotor. When I asked a friend of mine to do a set he said that unless they have almost no warp you won't be able to cut them because they are so close to being out of spec even brand new.
Old 03-19-2008, 02:44 PM   #9
BigART's Avatar
Wow, thanks. I had a feeling there was something to do with slotted rotors.
Old 03-20-2008, 08:03 AM   #10
I used to turn rotors everyday, and you can turn slotted and drilled. But to do it right the cutting blades need to be round carbide. If you use the triangle shaped bits you will not get a true cut. Everyone needs to ask the shop that is turning your rotors if they are using the round bits. They should know right away because the bits are not cheap. Even with stock rotors you get a much better cut with the round bits than with the triangle bits.
Always change your pads, never reuse them after getting new or turned rotors. I know that you could do this a few years ago, but pad formula's have changed. When you turn a rotor it has a magnetic field and it will allow all the loose metal that is in the pad to stick to the rotor. That is were uneven wear and the noise that we all hate come from.
Hemi5 is offline   Reply With Quote
