305/55/20 need help - Hemi Truck Club
Old 11-22-2010, 05:26 PM   #1
EVILRAM07's Avatar
305/55/20 need help
will they fit my 07 qc 4x4 or will they rub the front upper control arm since the 275/60/20 i am running now are close.
EVILRAM07 is offline   Reply With Quote
Old 11-22-2010, 07:07 PM   #2
HEMIRAM07
305/55/20 need help
I put 275-60-20 on mine and will have to put a spacer behind the wheel. They are close but rub when making sharp turns. My 07 is 2wh and there is no way a 305 would fit mine without rubbing.
Old 11-22-2010, 11:41 PM   #3
CavRam's Avatar
305/55/20 need help
I've got 305/55/20s on my 2WD. Get an occasional rub on the backside of the lower A-arm at wheel lock side to side.
Old 11-22-2010, 11:43 PM   #4
CavRam's Avatar
305/55/20 need help
Not at wheel lock, but giving you an idea what the 305/55/20s look like on the old stock 20" rim
Old 11-23-2010, 11:22 AM   #5
HEMIRAM07
305/55/20 need help
mine rubs at the front and back of the a-arm,,when turning sharp
Old 11-23-2010, 07:04 PM   #6
HEMIRAM07
305/55/20 need help
Quarter inch spacer fix mine,,no rubbing
Old 11-24-2010, 10:10 PM   #7
Haulin\ A
305/55/20 need help
I have 305/50/20 on the rear and 275/55/20 on the front. My truck is all wheel drive and the tires are with in a 3/16 of an inch in hight
