Wobble under acceleration - Hemi Truck Club
Old 04-12-2015, 07:21 PM   #1
My 2014 R/T has recently developed some exessive side to side body sway during hard acceleration. And it just seems to intensify once it starts. The truck does have a dealer installed 2-4 drop, but i didn't experience this before. Anyone else experiancing anything like this?
REDRAM is offline   Reply With Quote
Old 04-12-2015, 07:27 PM   #2
hemiram13's Avatar
I have a 2013 express RCSB that's stock suspicion wise and I also work for a dealer. At the dealer stand point I'm more than sure that the dealer would blame the wobble due to your suspension alterations. Did you have your beast aligned after you had the lowering kit installed?
2013 RC Express HEMI
Old 04-12-2015, 09:35 PM   #3
Have the alignment checked for sure. 2wd 1500 trucks normally don't get odd wobble issues like that unless something's way out of wack
Old 04-13-2015, 09:23 AM   #4
REDRAM
Looks like your #1 Post so:
Old 04-13-2015, 01:33 PM   #5
Old 04-13-2015, 02:02 PM   #6
john
:Kneel2Hem i:
Old 04-13-2015, 02:30 PM   #7
The newer models with coils springs might be loading and unloading causing the rear to move back and forth. I understand as they go up and down they also go side to side.
Old 04-13-2015, 03:13 PM   #8
Matt
MANual_puller's Avatar
Some tire compounds don't squeal. Are you sure you aren't just spinning? I couldn't imagine a 4 link suspended rear end moving around too much unless something is broken.....
Old 04-13-2015, 03:29 PM   #9
I am making the assumption that the alignment was done after the drop install. Front tire wear looks good so far.
Old 04-13-2015, 03:31 PM   #10
The two times this has happened, I was already up to around 70 or so, dont think it was breaking loose.
