WHat's best raise the front or lower the back 2500 - Hemi Truck Club
Old 01-12-2008, 03:45 PM   #1
Grampa\s Hemi
We have a 2005 2500, I would like it to be uniform. Which is the the best way to handle this?
1) Raise the front 2"
2) Lower the back 2"
Old 01-12-2008, 10:18 PM   #2
mudchucker's Avatar
Is it 2wd or 4wd?
Old 01-12-2008, 10:21 PM   #3
Well I have a 04 1500. I used a 2" coil lift along with new shocks and front end alignment. I was told stock shocks did not have enough play for the exra 2" of lift. 100 for the coils, 120 for the shocks, 100 labor and 75 for alignment.
Old 01-14-2008, 04:57 PM   #4
Grampa\s Hemi
It's a 2wd. I noticed 3 shims over the back axle maybe 1 1/2" total, can I remove these without causing any damage or needing a shim to adjust for the angle? This message has been edited. Last edited by: Grampa's Hemi, document.write(''+ myTimeZone('Mon, 14 Jan 2008 15:53:12 GMT-0800', '14 January 2008 06:53 PM')+''); 14 January 2008 06:53 PM
Old 01-16-2008, 03:31 PM   #5
brand_x_racing's Avatar
Id personally just do a front coil spacer if you haul any weight in your truck, when you drop the rear end it has less weight carrying capacity hence the axle is closer to the bump stops, Just my personal opinion!!!
Old 01-16-2008, 09:26 PM   #6
Grampa\s Hemi
Do does anyone know of a good shop that can install front springs and front end alignment in the Houston Texas area.
Old 01-21-2008, 08:41 AM   #7
What side of town are you on?? I know alot of shops all around town!
Old 01-21-2008, 02:28 PM   #8
Grampa\s Hemi
Oak Ridge North (Across from The Woodlands Mall)
Old 03-13-2008, 12:48 AM   #9
Grampa\s Hemi
I live in Oak Ridge North (The Woodlands) I have the 2" spacers, I need the right shocks and a shop to install everything and do the alignment.
Old 03-13-2008, 12:55 AM   #10
Grampa\s Hemi
What shocks did you buy?
