Vibration. - Hemi Truck Club
Old 07-16-2015, 09:13 PM   #1
Vibration.
Hey all,
Quick question. How can I tell if a vibration I'm getting when braking is the front rotor(s) or the lower ball joints? Only happens when I brake, so I'm thinking warped rotor(s). But I don't know is there a way to test it? I heard if you jack up the front end and you can"wiggle" the front rim then it's your ball joint. Does that sound right? I also heard that if you jack up the front end and the wheel falls off completely, then you have another situation all together...
RumRunner
2005 Regular Cab
Short Bed
5.7 H.E.M.I.
4x4
Middle River, MD
RumRunner is offline   Reply With Quote
Old 07-16-2015, 09:26 PM   #2
Matt
MANual_puller's Avatar
Usually warped rotors can be felt in the pedal. They aren't very common. Have to get the brakes very hot to warp...
Old 07-16-2015, 09:50 PM   #3
It's more in the steering wheel and the dash sounds like it's going to fall out.
RumRunner
2005 Regular Cab
Short Bed
5.7 H.E.M.I.
4x4
Middle River, MD
Old 07-17-2015, 04:21 AM   #4
Make about 10-15 stops from 45-20 by then the rotors should be nice and warm and if it's the brakes you will likely feel it in the pedal but should deff feel the steering wheel Shake side to side when braking. If the wheel shakes just buy all new stuff for front brakes and do yourself in drive way cheaper.
To check the balljoints jack the truck up under the lower control arm and then with a good size pry bar lift and lower the wheel that's jacked from underneath. If the joint has play you will feel it this way.
Old 07-17-2015, 07:44 AM   #5
Old 07-17-2015, 07:58 AM   #6
Question
Guessing it's the rotors However if the wheel falls off that's another story ...
Old 07-17-2015, 08:24 AM   #7
Gold-Member
kcd1369's Avatar
Most likely warped rotor. Do like Charged392 said and you will know for sure.
If it was ball joints I would think you would feel it in the steering more of the time then just stopping. How does the steering wheel feel when you hit bumps? if it steady probably not ball joints.
Old 07-17-2015, 10:02 AM   #8
thanks all I'll give the suggestions a try and let you know. The rotors and pads I've done before so that isn't a problem. The lower ball joints on the other hand...ugh, I'll pay someone to do that for me. Thanks for the info.
RumRunner
2005 Regular Cab
Short Bed
5.7 H.E.M.I.
4x4
Middle River, MD
Old 07-17-2015, 12:46 PM   #9
Gold-Member
kcd1369's Avatar
Old 07-17-2015, 01:12 PM   #10
While you are in there I would also check the wheel bearings. good luck..
