Traction bars - Hemi Truck Club
Old 10-12-2014, 10:27 AM   #1
Truck of the year 2014
Belgiquebasterd's Avatar
Traction bars
Due to the high shipping charges and different setup on my truck due to yearly automobile inspection over here in Belgium I built my own instead of buying Keith's set.
I used to run a homebuilt version of the caltracs but due the system design and some mistakes on my part while building I was left with slack in the suspension and it rattled which was very annoying.
I reused the rear caltrac setup, it's based of the bottom U bolt plate instead of a seperate welded clamp like keith uses. This way I can easily remove the entire thing and swap in a different plate for the yearly inspection.
Because of the fact that I used the u bolt plate, the bars were not in line with the frame and I had to use a offset bracket. I opted to use bolts instead of welding it to the frame again for the yearly inspection, hopefully they won't notice the holes in the frame.
Marking
Point of no return
Sleeve tube in to prevent the frame from buckling when tightening the bolts
Welded
Ready for paint
Side mount bracket, recently bought a set of dimple dies and really wanted to use them lol , did put them in wrong, the bulge should be down lol. Did al the bending of the plate with my 20 ton press, worked perfectly.
Bracket in place, the bars are nice n close to the frame, but hopefully not too close so that they touch when the suspension bottoms out, time will tell.
Thanks for watching
Old 10-12-2014, 11:05 AM   #2
Nicely done..
Old 10-12-2014, 11:54 AM   #3
Nicely done.
Old 10-12-2014, 01:37 PM   #4
Old 10-12-2014, 02:25 PM   #5
Cool
Good job.
Old 10-12-2014, 09:53 PM   #6
How long did you make the bars? Really like the forward brackets.
Old 10-12-2014, 10:55 PM   #7
65"/165cm, no real reason for that specific length except it was the easiest furthest forward location for the forward bracket. Further forward I would've had to pass the body mount on the frame and therefore lowering the whole setup, which I didn't want to do.
Old 10-13-2014, 05:31 AM   #8
Gila Hemi's Avatar
Do you have the equivalent of TÜV there? If so, they'll notice it...
Old 10-13-2014, 05:29 PM   #9
Board of Directors-Bill
arocketman's Avatar
Nice work!
‘05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 10-13-2014, 07:00 PM   #10
Board of Directors "Phil"
GodsRodsHEMI's Avatar
nice work
silver 04 SLT QC 4x2/HEMI/ 20"chrome wheels/A.R.E. LSII Tonneau/HEMI logoed bedliner/
tow/haul button/full power Leather seats/ HEMI embroidered headrests/Billet style "HEMI" door inserts and door pillar inserts/black DEE ZEE Nerf bars/ custom graphic stripes by westside vinyl & graphics/Tinted windows/billet(brushed)fuel door(locking)/HEMI with rams head embroidered floor mats/H.T.C. Trible window Logo's/Husky Liners Mudflaps/Sonar gen 3 taillights/Super chip programer
Shaved Tailgate handle w/Sir Michaels handle relocator.
True Duals w/Flow master 50 series (Delta Flows) and IMCO performance exhaust X pipe and LXP stainless tips.Mopar rear wheel well liners.
Billet "BIG MOUTH GRILLE" by Precision grilles,T-REX Billet bumper insert.,HAMBEK SIXPACK HOOD W/RamAIRBOX
Future mods: ??
view my website at http://philbonc.50megs.com/photo6.html
more pics from HEMI in the hills taken by KenandJenn 2005
2011 SRT8 Challenger 392 HEMI Inaugural edition #0925 of 1100 made for USA
GodsRodsHEMI is offline   Reply With Quote
