To those runnig aftermarket rear sway bars - Hemi Truck Club
Old 08-24-2016, 05:53 PM   #1
My truck is in desperate need of a rear sway bar. I have been doing some research and apparently Hellwig and Beltech are the most popular. I have been looking into Beltech the most because they offer the u-bolts that fit the dana60 rear (3.5" axle tubes). Anyways, to those that have a Beltech, did you have to drop the gas tank to install the driver side bracket?
Do you guys recommned another bar?
Old 08-24-2016, 05:59 PM   #2
Max, you already have that heavy axle and you are going to need traction bars.. you sure you want a sway bar too?
Old 08-24-2016, 06:03 PM   #3
Exclamation
I can only speak for my Hellwig bar...and I would not trade it for another one...the difference is extremely noticeable...I also must add that I installed Bilstein shocks all around at the same time as the rear sway bar. There are certainly other excellent quality combos out there...this installation was just very straightforward and easy with no problems .
with your final selection .
Old 08-24-2016, 06:12 PM   #4
The truck becomes a little unpredictable when taking any sort of curves and hitting bumps and the same time. I can feel the rear skipping laterally and when it happens at highway speeds over 70 it is a little scary
At first, i thought of a watts link or a panhard bar, but i do not know how effective it would be when running leaf springs
I am open to advise
Old 08-24-2016, 06:13 PM   #5
Thanks, i will keep the shocks in mind as well
Old 08-24-2016, 06:29 PM   #6
CavRam's Avatar
Know what you mean on that sketchy feeling from the rear tires. HTC discussed this quite a bit around 2005 or so. Remedies were don't over inflate tires, in fact carry a couple of PSI below recommended; quality shocks; leveling or lowering suspension.
On my 04 I carried a couple of PSI under recommended, installed Bilstien shocks, and leveled by using 2 inch drop shackles and removing helper springs. Made a world of difference. Rear sway bars would have been the icing on the cake, but I was satisfied with the improved performance already.
2014 Ram 1500 Express
Old 08-24-2016, 06:59 PM   #7
I checked again and it is actually Hellwig that makes the kit with the 3.5" ubolts
Thanks for the tips!!!
Old 08-24-2016, 07:01 PM   #8
You will like it . Add Bilsteins and you will be good to go for a long time .
Old 08-24-2016, 09:32 PM   #9
Max, actually that's how I'm setup. Lowered 6 in the rear, helper spring removed with Caltrac's. I run low pressure in the rear (28). It felt like it was wiggling and I changed shocks and it was good. I use to run the country back roads, but actually haven't for some time. But the truck feels solid at speed.
Old 08-25-2016, 02:40 AM   #10
Board of Directors-Bill
arocketman's Avatar
Helper spring removal for sure!
You'll be happy with the Helwig set up.
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
