rear sway bar for lifted truck Powered by Eve For Enterprise - Hemi Truck Club
Old 11-22-2008, 02:19 PM   #1
my truck sways like i'm going to loose controll when i change lanes at high speeds so i was thinking maybe a sway bar would help...(my tires are all good,air,ect.)..i have a 2008 1500 w/fabtech 6' likt kit and i'm looking for a rear sway bar and i can't find one for a lifted 6'' truck,so if someone knows where i can get one plese speak up or what else mite help the sway...thank you
fast fred is offline   Reply With Quote
Old 12-20-2008, 08:54 PM   #2
I dont know if the sway bar would help W/the trouble you are having.But if you cant find one to fit you could get a bar and make longer links.
Ram1500 is offline   Reply With Quote
Old 12-21-2008, 03:48 PM   #3
Old 01-21-2009, 10:25 AM   #4
brand_x_racing's Avatar
I HAVE A 8" KIT ON MY 77 CHEVY WITH NO SWAY BARS BUT I HAVE LEAVES AND DID SOME WORK TO THEM, SO THERE ARE SOME THINGS TO CONSIDER, WITH RIDING TALL!
SHOCKS MAKE YOU OR BREAK YOU, WHAT SOMETIMES RIDES GREAT HAS NOTHING TO CONTROL YOUR BEAST! IS YOUR ALIGNMENT GOOD?
SWAY BAR CAN BE FITTED FOR THE REAR, OR GET THE SUPERLIFT SUSPENSION BLOCKS WITH TRAC BARS AND THAT WILL HELP TOO. THATS IF YOUR USING BLOCKS, AND SPRING WRAP ON THESE TRUCKS IS QUITE A BIT,
FOR A BAR THAT COULD PROBABLY BE MODIFIED IS THE BELLTECH, THE WAY THE HELLWIG MOUNTS WOULDNT DO YOU ANY GOOD AND WOULD BE IN THE WAY. ANOTHER IDEA IS GET A USED BAR OFF A F-350 FURD 4WD WITH TOW PACKAGE, HAS A BAR ON IT AND SOME DECENT MOUNTS, AND IS EASY TO MAKE NEW ENDS WITH HEIM JOINT PIECES FOUND ONLINE OR AT SPEED SHOPS!
MIGHT CHECK CARLI SUSPENSIONS FOR A SWAY BAR AND MAYBEE A SHOCK UPGRADE,
Old 01-21-2009, 11:18 PM   #5
madcat's Avatar
quote:FOR A BAR THAT COULD PROBABLY BE MODIFIED IS THE BELLTECH,
it wouldn't take much to fab up some longer end links.
Old 01-22-2009, 11:18 PM   #6
rdsetgo's Avatar
How well do these work??? I am thinking of adding one to my Ram, I am not going to lift it either!!
Old 01-23-2009, 10:55 AM   #7
madcat's Avatar
top 3 of my favorite mods so far... if you drive spirited around corners.... these will "plant" your rear end. Night and day difference for me. I cant believe they are not standard from the factory.
Old 01-23-2009, 12:04 PM   #8
I totaly agree, I didnt believe it till I got it on, and WOW!!!!! Totaly different truck and I totaly love it,
Trust me for the $$$$ its one of the best mods to ever have. I wouldnt have it any other way from here on out!
Old 01-23-2009, 02:55 PM   #9
Makes a big difference. Great MOD and it is not tough to do either.
Hemi317 is offline   Reply With Quote
Old 01-25-2009, 04:05 PM   #10
rdsetgo's Avatar
Which one did most of you guys go with??
