Pinion angle? - Hemi Truck Club
Old 03-13-2008, 10:45 PM   #1
Pinion angle?
I just lowered my truck and I was goin to set the pinion angle at -2 degree. Is that a good setting or do I need to go lower or higher?
Texas*hemi* is offline   Reply With Quote
Old 03-14-2008, 01:02 AM   #2
Pinion angle?
have you checked the actual angle? my friend has an f-150 with a 3/5 drop, i can find out what shims we put in his truck i cant remember, but it really helped alot, you will notice the difference, if you are getting a vibration right now, with the shims it will go away, plus it is alot easier on the rearend.
Old 03-14-2008, 09:09 AM   #3
Pinion angle?
Well I have a slight vibration at full throttle. It's not bad but I am about to weld the spring perches and I want to get set right. I used a flip kit and it's easy to adjust. I geuss I will adjust it until it's smooth.
Old 03-14-2008, 01:27 PM   #4
TheBoss's Avatar
Pinion angle?
-2? I hope you don't mean in the angle of a mountain, if you get my analogy.
Old 03-14-2008, 02:15 PM   #5
CentralTexHemi's Avatar
Pinion angle?
http://www.carcraft.com/howto/91758/index.html
http://www.quickperformance.com/Tech...nion_angle.htm
Old 03-14-2008, 03:09 PM   #6
TheBoss's Avatar
Pinion angle?
Good links Wade.
Old 03-15-2008, 07:39 PM   #7
Pinion angle?
Thanks alot for all the help. The links that were posted really helped. I thought I had the pinion angle thing figured out but i'm glad i know how to really do it now. THANKS
