OE alignment Cam boltsAdjusters - Hemi Truck Club
Old 12-07-2017, 09:53 AM   #1
Mark G Senior Member
bada44's Avatar
I am looking for a set of OEM cam adjuster bolts for 2003 Ram RWD does anybody have a set they want to get rid of.
Please Donate today!
https://www.stbaldricks.org
I stand for the flag!
[email protected]
Old 12-07-2017, 05:11 PM   #2
They didn’t come stock 2003 is just a sliding upper control arm I believe any way.
Old 12-07-2017, 05:38 PM   #3
Yes, oem is just a slider, i added adjusters. They seem to make aligning a nit easier. I dont have bump steer, drives and rides true.
Old 12-07-2017, 05:47 PM   #4
bada44's Avatar
I have an eccentric kit in there.... but I think it is causing the control arms to squeak so I'm looking for the OE bolts I can't seem to find the ones that were removed.
[email protected]
Old 12-07-2017, 05:58 PM   #5
Same here, I haven't seen the originals for a long time..
Old 12-07-2017, 05:59 PM   #6
The bolts won’t squeak it’s likely a bushing or ball joint making the noise.
Old 12-07-2017, 06:14 PM   #7
bada44's Avatar
everything was replaced twice the only thing I never replace was The Eccentric kit
[email protected]
Old 12-07-2017, 06:44 PM   #8
The kit won’t make noise unless it’s loose trust me on that. The bushings will squeak if they were tightened down in what I call bind or suspension hanging not level on ground. Joints will also squeak. When do you get the squeak?
Old 12-07-2017, 06:48 PM   #9
bada44's Avatar
it's squeaking under normal driving... The truck is in South Carolina and it is cold there now and it's squeaking even worse.
[email protected]
