Need Torque Settings for Suspension Parts - Hemi Truck Club
Old 01-12-2015, 10:07 AM   #1
mopar_mike's Avatar
Hi all, hopefully soon I'll be getting my lowering part and install them. What I need is the torque settings for different parts of the suspension. Here is the list that I am looking for. This is for a 2005 Ram 1500 2WD.
Upper front ball joint,
Lower front ball joint,
Tie rod,
Unit bearing hub
Front leaf spring bolt
Rear leaf spring bolt
Rear axle U-bolts
Thanks a bunch!!!
2005 Ram 1500 SLT RC/SB HEMI 2WD Build Thread
1997 Ram 2500, CC/LB, Cummins, 4x4
mopar_mike is offline   Reply With Quote
Old 01-12-2015, 10:18 AM   #2
Truck of the year 2014
Belgiquebasterd's Avatar
Straight from the manual, if you give me your email, I can 'wetransfer' you the full manual if you want.
Front
Rear
Old 01-12-2015, 10:32 AM   #3
mopar_mike's Avatar
Thanks man, you rock!!!
Sent ya a PM with email address. Thanks!
