Lower - Hemi Truck Club
Old 04-27-2013, 09:01 PM   #1
dodhem06's Avatar
Lower
Want to lower my 2006, but keep the stock 20"s best suggestion...
2006 1500 Quad Cab "Lone Star" Edition.
As a courtesy to the other drivers, this is what a HEMI looks like from the front.
dodhem06 is offline   Reply With Quote
Old 04-27-2013, 09:18 PM   #2
AlbertaHemi's Avatar
2"/4" drop. I used the McGaughy's deluxe kit and have been very happy with it.
Dave.
HTC MEMBER #2460
Old 04-28-2013, 05:15 AM   #3
dodhem06's Avatar
Thanks!
Old 04-28-2013, 08:03 AM   #4
Yep, spindles and a flip.
Old 04-28-2013, 08:16 AM   #5
2/4 drop will be perfect 4/6 rubbing likely
Old 04-28-2013, 10:10 AM   #6
Have to disagree with the flip kit due to the problems that I had.
http://www.hemitruckclub.com/forums/...lem-11805.html
It would be better if you installed lowering leaf springs. That way you don't have to use the longer rear shackles that will change your ride and tow quality.
Old 04-28-2013, 10:41 AM   #7
Stu, not sure how you got into that mess. But there have been hundreds of flip kits installed without the issues you had/have. Most all problems come back to the axle rotating after install altering the driveshaft angle and in the extreme cases destroying the driveshaft. I know most if not all of the guys who have used flip kits will tell others to install the kit, check your angles and go have the perches welded. It's cheap insurance that keeps everything lined up and safe. Our Ram springs are IMO relatively flexable and wrap easily (wheel hop) when launching, adding something to control this movement is also a good precautionary step to keep from damaging the drive train. If you are using the same spring as before the drop then you will have the same spring rate after the drop as it's the same spring. That's my 2 cents.
Old 04-28-2013, 11:31 AM   #8
I agree and I know what controls that wrap very well
Longbars
Old 04-28-2013, 12:18 PM   #9
2/4 mc g's kit has been doing me good, but i got the springs up front not spindals
Old 04-28-2013, 03:53 PM   #10
David
ATXHEMI's Avatar
It really sucks you have to use a flip kit to go 4" in the back. I had a 3/5 drop on my f150 and just changed the shackles and hangers in the rear. Only needed a flip kit to go 6".
