leveling kit and alingment - Hemi Truck Club
Old 07-06-2008, 05:15 PM   #1
Im going to put on a leveling kit on my 07 4x4. When I do what is going to be out on the alingment? Will it be camber, caster or toe? I have an alingment machine at work but im not sure how camber and caster is set on this truck so I can set toe but may need to take it to an alignment shop for camber and caster.
Tallj2000 is offline   Reply With Quote
Old 07-06-2008, 09:05 PM   #2
Freeze's Avatar
Can't help you on the alignment part. I just take my truck down the street to Merchant's Tire.
Old 07-09-2008, 07:38 AM   #3
I got a question about the torsion bar. How do you adjust them to level the front out?
Many thanks!
Mike
TVHemi is offline   Reply With Quote
Old 07-10-2008, 09:52 PM   #4
code3hemi's Avatar
Find your torsion bar and follow it towards the back of the truck about mid way under cab you will see a bolt there start to adjust one side about half way in and then do the other side,then take both up about 3/4's of the way and start measuring the underside of the front fender wheel well and get them even.hope this helps if not I can post pics.
code3hemi is offline   Reply With Quote
Old 07-11-2008, 09:25 AM   #5
Thanks for the help! I was looking at the bolt, and was wondering if that had anything to do with it. If I run into any problems, I will posting for any help!
Thanks again!
Old 07-12-2008, 07:47 PM   #6
code3hemi's Avatar
Old 07-12-2008, 10:10 PM   #7
Freeze's Avatar
I recommend jacking up the front end to take most of the load off the suspension before you start cranking on the t-bar keys.
Old 07-13-2008, 01:53 PM   #8
code3hemi's Avatar
Old 07-15-2008, 07:00 PM   #9
I did jack the front end up, and put it on jack stands. Seems the passenger side did not need as many cranks on the bolt as the drivers side did. I am really happy with the way it came out, but just giving a few more miles to readjust it. I got about 2 inchs out of it. Ride does not seem that bad, actually feels better when I hit some bumps! Thanks for all the help with this!!!!
Old 07-16-2008, 11:53 AM   #10
Gar
Gar's Avatar
Show us some pics! I loved how my '05 looked with the torsion bars cranked.
Gar is offline   Reply With Quote
