issues... - Hemi Truck Club
Old 04-15-2012, 03:39 PM   #1
so my steering wheel makes noise when i turn it and my front end squeaks when i go over bumps... i am almost positive that i need to lube my ball joints and sway bar bushings, but sadly i have no idea what my bushings look like?? or what i need to do to properly lube them.. if anyone can help it would be much appreciated! thanks!
STEF
lewis_57 is offline   Reply With Quote
Old 04-15-2012, 03:39 PM   #2
STEF
Old 04-15-2012, 03:40 PM   #3
just realized this might be important.. lol its a 2005n dodge ram 1500 SLT 2WD ))
STEF
Old 04-15-2012, 05:01 PM   #4
Stef, first welcome to the forum. I suspect you are going to find out the tie rod/ball joints are not serviceable. See if you can isolate the squeaky joint and then you'll get to change it out. Good luck...
Old 04-19-2012, 02:52 PM   #5
Big Red One's Avatar
You might also check the power steering fluid level. If the fluid is low it will cause toe power steering pump to make noise which you can also feel in the steering wheel
2005 Ram 3500 Reg Cab 4x4 Dually, Getrag 6 spd (G56), 17" Alcoa Classics, Magnaflow, Bubba Rope, AEM Brute Force
Big Red One is offline   Reply With Quote
Old 04-19-2012, 07:52 PM   #6
reen4967's Avatar
i have the exact same problems and my power steering fluid isnt ever low when i check it. just gave up on trying to figure it out
04 dodge ram rc/sb hemi
03 dodge ram qc/dually cummins
reen4967 is offline   Reply With Quote
