Inner tie rod ends/links - Hemi Truck Club
Old 02-27-2014, 06:58 PM   #1
Falcon's Avatar
So after I installed my 2" leveling kit, I took it to have it aligned. When I did, they said that my inner tie rod end links were worn so they couldn't align it. So I call up oreillys and ordered some. When I look at there website and try to find which ones I ordered, the pic shows what I thought to be the outers....even though the description says inner. I am not knowledgeable at all about suspension/steering parts so I am just not sure. When I do a google search, I get tons a various looking parts. Anybody kind enough to post a pic of the inner tie rod end links so I can make sure I am getting/replacing the right part? I am assuming the outer ends connect directly to the lower control arm and the inner ends are on the other side of the tie rod. How hard are the inners to replace? I was able to install the levelling kit and sway bar end links myself. Thanks for any info and advice! (info on my ram should be in my sig)
__________________________________________________ _______________
~Kyle~
"The pain of a poor product lasts far longer than the thrill of a good price."
2007 HEMI Ram 1500, 4x4, Quad Cab, ST - SOLD
2006 Ram SRT-10, Quad Cab - SOLD
2007 HEMI Ram 1500, 4x4, Quad Cab, Big Horn Edition......work in progress.
Falcon is offline   Reply With Quote
Old 02-27-2014, 07:38 PM   #2
boedacres's Avatar
outer tie rod ends are about 6-8 in long the inner tie rod are about a foot long
Old 02-27-2014, 07:39 PM   #3
Falcon's Avatar
Are they both shaped the same?
~Kyle~
Old 02-27-2014, 07:45 PM   #4
boedacres's Avatar
no the outer has a female end and a stud that mounts to the spindle side. the inner has a long threaded end
Old 02-27-2014, 07:47 PM   #5
Falcon's Avatar
Ok.....that is what I thought. I believe these are what the guy ordered. It says it is an inner but to me looks like an inner.
http://m.oreillyauto.com/mt/www.orei...3448&ppt=C0203
~Kyle~
Old 02-27-2014, 07:49 PM   #6
boedacres's Avatar
outer tie rod
Old 02-27-2014, 07:50 PM   #7
boedacres's Avatar
inner,
Old 02-27-2014, 07:55 PM   #8
Falcon's Avatar
Shoot.....that is what I thought. Hope the pic is wrong on their website then. Thanks buddy! Changing it seems pretty straight forward to me but how hard are they to change?
~Kyle~
Old 02-27-2014, 08:45 PM   #9
Outers are simple loosen jam nut,remove spindle nut , split tie rod from knuckle (few smacks to knuckle where stud goes thru works fine), then count turns off, reverse process
Inner start with outer directions then remove jam nut, remove outer boot clamp, remove inner boot clamp, remove boot carefully, loosen inner tie rod with inner tie rod tool or a pipe wrench will do, install new inner with locktite on threads fairly tight then reverse process
It's easy to say but doing it another story have fun
Old 02-27-2014, 09:31 PM   #10
Falcon's Avatar
Thanks buddy!
~Kyle~
