Groundforce Drop Kit - Hemi Truck Club
Old 09-24-2011, 07:19 AM   #1
jrodshemi's Avatar
I was just wondering if anyone has any good or bad things to say about this kit?
My cardomain garage: http://www.cardomain.com/id/Hemi_Man_1984
2004 QC SB 2wd
Magnaflow Side exhaust
K&N FIPK
Diablo Sport w/custom tune (93 octane)
2" rear lowering shackles
Billet lower grille
Completly debadged
steel cowl hood
tinted tails and 3rd brake light
10,000k HID head and fog light kit
truxedo low pro tonneau
8" shorty antenna
brushed aluminum dash kit
06 chrome clad wheels
jrodshemi is offline   Reply With Quote
Old 09-24-2011, 07:19 AM   #2
jrodshemi's Avatar
2004 QC SB 2wd
K&N FIPK
Billet lower grille
Completly debadged
steel cowl hood
8" shorty antenna
Old 09-24-2011, 08:31 AM   #3
AlbertaHemi's Avatar
From what i've heard its good, i have a McGaughy's 2/4" drop and its an excellent kit, one of my favourite mods.
Dave.
HTC MEMBER #2460
Old 09-25-2011, 12:50 AM   #4
Mr. Freeze
VA4MEDS's Avatar
Groundforce is overpriced IMHO
Check out Belltech or McGauhy's prices. Both excellent products.
Old 09-25-2011, 05:45 PM   #5
reen4967's Avatar
mcgaughys is way cheaper and its great. sometimes i walk outside and im like damn my truck is badass just because of the drop kit. hands down best mod.
04 dodge ram rc/sb hemi
03 dodge ram qc/dually cummins
reen4967 is offline   Reply With Quote
Old 09-26-2011, 01:21 PM   #6
David
ATXHEMI's Avatar
I had a Western Chassis Drop kit on my F word. Only complaint i had was the bushings were very squeaky. But very easy to install in a driveway.
Old 11-10-2012, 09:34 AM   #7
prod646's Avatar
I don't see a 2/4 drop kit for a 4x4 quadcab on the McGaughys website. Is their kit for 2WD useable?? I see a Groundforce 2/4 drop kit specifying a 4x4 kit but it is like 750 bucks on ebay
2012 Ram 1500 Hemi Express 4x4 RCSB BLACK
OLD RIDE 2003 Dodge Ram Hemi 4x4 QC
Graphite Metallic SRT-10 Hood
Magnaflow Y-pipe and 14 inch Muffler Jet 180 Thermostat
K&N CAI Sonnax LP Booster
DS Predator 93 Tune TB Spacer
Taylor Shorties NGK 5306 Plugs
03 TMR Delete Mod
prod646 is offline   Reply With Quote
Old 11-10-2012, 09:12 PM   #8
You need to talk to someone who has a 4x4 and actually done this, but I have seen several 4x4 guys use the 2x drop spindle and the rear flip kit on both 4x4 and 2x is also the same. The springs in either case are reused so there should be no problem with different spring rates. Good luck.
Edit: I knew Trup did his 4x4 a couple of years ago and here is a thread showing what was done.
http://www.ramforum.com/f46/03...4x4-drop-help-21593/
Old 11-11-2012, 03:34 AM   #9
prod646's Avatar
Thanks for the link Greg I will continue to study on this.
03 TMR Delete Mod
Old 11-12-2012, 08:26 AM   #10
FAhemiST's Avatar
the 4wd's require the spindles in the front. the cheap 2wd kits use front springs, the more expensive ones use the spindles. the rear flips are all the same.
11 White CC 4x4
