Drop shackles Tips/suggestions - Hemi Truck Club
Old 02-27-2008, 02:55 AM   #1
zwa21's Avatar
My shackles came in the mail yesterday . Are there any tips or suggestions for the install? Or anything I should look out for? It looks like it pretty simple, but wanted to get the scoop for sure.
Old 02-27-2008, 06:14 AM   #2
FAhemiST's Avatar
Make sure you grease them up well.
Old 02-27-2008, 01:00 PM   #3
zwa21's Avatar
Are the bolts hard to break loose? How much torque do the new shackles require?
Old 02-27-2008, 01:30 PM   #4
The instructions are pretty straight forward. Nothing too difficult. All the torque specs should be in the directions. Good luck. Take before and after shots.
Old 02-27-2008, 06:05 PM   #5
when doing this job-I would put the rear part of the frame on jackstands,then,I would jack up the rear axle a little-unbolt the lower shock bolts,then-unbolt the lower shackle bolts,now,I would lower the floor jack which should drop the leaves down from the shackles.Remember,before starting-I would spray some type of penetrant(wd-40 or stronger)on all the bolts and let them soak in.Hope this helps a little.
Old 02-27-2008, 07:26 PM   #6
zwa21's Avatar
Thanks guys. I read my directions, but they were pretty tore up inside the box. Wanted to make sure I didn't miss anything.
