Drop on bump stop - Hemi Truck Club
Old 11-09-2017, 07:45 PM   #1
Drop on bump stop
Installed a pair of 2" drop springs on front and 2" shackles on rear
2005 1500 Quad 5.7 short bed , drop 2 shocks on front
when we got through the bump stop was touching the a frame in the front
Looks great rides like a wooden wagon
Can i replace the bump stops with shorter one's
Did the same thing to my 02 1500 4.7 w/long bed no problems at all
any suggestions
fever42 is offline   Reply With Quote
Old 11-09-2017, 09:00 PM   #2
Lowering the front you have to cut the factory stops/bracket off and bolt on a timbren or polyurethane aftermarket mount where the factory was.
Old 11-10-2017, 05:40 AM   #3
The steel cup has two spot welds, grind the weld thar you can easily reach and drive a chisel under it and break it off. Smooth the welds and give is a shot of paint. The hole is already there for the new mount.
Old 11-10-2017, 06:50 AM   #4
Truck of the year 2014
Belgiquebasterd's Avatar
I reused the original bumpstop cup, removed the cup, holesawed a hole diameter of the cup in the frame support and welded the original cup back in flush this time.
Before
Drilling the hole for the cup
Result
Old 11-10-2017, 06:16 PM   #5
Thanks guys I ordered me some new Timbren today be here tomorrow and going to fix this ride
