Coil Cut Question - Hemi Truck Club
Old 12-12-2015, 06:18 PM   #1
JesterUno's Avatar
Coil Cut Question
I have already decided to cut the rear coils so don't try to talk me out of it! lol
I'm going for 2-3 in of rear drop just to level the truck out. The rear has after market in the coil helper bags, so I'm not worried about too much bounce since I can stiffin up the ride with those.
My question is, is it better to cut the bottom of the coil or the top.?
Thanks,
JesterUno is offline   Reply With Quote
Old 12-12-2015, 06:47 PM   #2
Have to look at the coil to see which end lends itself best to being cut.
Old 12-12-2015, 06:51 PM   #3
JesterUno's Avatar
Some one here has done it already...which end did you cut?
Old 12-13-2015, 08:47 AM   #4
CavRam's Avatar
First, I didn't cut, I installed 2" drop coils on the rear for a leveled look.
Our coil springs coils are tapered at the top. Not a spring expert, but I believe it has to do with something called a progressive spring rate for the coil.
That being said, cutting the bottom coil will have the lesser effect on the spring's performance.
Anybody confirm or deny?
2014 Ram 1500 Express
Old 12-13-2015, 09:06 AM   #5
Can you post a picture of the spring you took out? That would tell us a little...
Old 12-13-2015, 11:39 AM   #6
Sure hope you come out with a 'balanced rate' after cutting your springs .
Old 12-13-2015, 06:19 PM   #7
CavRam's Avatar
Exactly why I didn't cut. My Ram is a daily driver and I did not want to have the back end get squirrelly on me by messing with the spring integrity. I used Mcgaughy 2" drop springs that are made for Ram 1500s. Got the level look on my quad cab and no compromise on the ride and handling.
Old 12-13-2015, 06:46 PM   #8
When the 4g's are lowered don't they need the panhard and links adjusted to realign the pinion angle and center the axle?
Old 12-13-2015, 07:09 PM   #9
CavRam's Avatar
Some do with the 2" level, but it is not necessary. The folks that slam em are having to replace or remount their panhard.
Old 12-13-2015, 07:12 PM   #10
I would think the 4g would be relatively easy to bag. Especially with the prices getting better.
