ball joints and ucas - Hemi Truck Club
Old 05-03-2014, 02:46 PM   #1
Farrrrrr East Coast
NewfieBullet's Avatar
does anyone know if the upper ball joint can be replaced or does it have to be the whole upper control arm? i got the moog part number from rock auto but no picture, dunno if the control arm is with it or not. dealership wont warrenty it because of the lift ( knew that anyway) so im just gonna go ahead and do both sides before i get my wheel alignment.any help or part numbers appreciated. im not getting the rough country or fabtech ones, way to much money and my truck sees little abuse, i only avg 11000kms a year and 98% pavement...think i ruined the ball joint when i had the bills maxed stacked on the 6"rcx. when i put these in im also dropping down to .7 from 1.4. the drivers side is almost gone so id rather do both and get it over with..thanks in advance ..my lowers seem fine btw.
Old 05-03-2014, 03:06 PM   #2
It's an entire arm for the upper align after for sure
Old 05-03-2014, 03:50 PM   #3
Farrrrrr East Coast
my alignment is out of wack, my front tires are wore pretty bad...55$ for moog's seem pretty cheap for a ball joint and uca
Old 05-03-2014, 04:40 PM   #4
boedacres's Avatar
moog has a life time warrenty
Old 05-03-2014, 05:47 PM   #5
Only run moog makes no sense not too
Old 05-04-2014, 04:19 PM   #6
Farrrrrr East Coast
so i didnt get moog...wasnt sure on them being all in one and couldnt get a clear answer...not sure what these are got em from rock auto, guy said they would be fine, called them a "forged" uca with greaseable ball joint and made in canada . good enough for me. also got powerstop ceramic pads front and rear, and a set of drilled and slotted powerstop rotors for the front. back rotors are still smooth as butter so i didnt bother.worse case i ruin a set of pads. but i figure the upgrade up front was long overdue with the lift and bigger tires.
Old 05-04-2014, 04:36 PM   #7
Old 05-07-2014, 02:25 AM   #8
Freeze's Avatar
Your only possible upgrades from Moog are UCAs from CST, KORE, or Pure Performance.
Old 05-07-2014, 05:46 AM   #9
preachp's Avatar
Hi All,
Someone pointed these out.
Zone Offroad Heavy Duty Upper Control Arm Kit: 06-14 Ram 1500 D2301
preachp
Acts 1:11 Which also said, Ye men of Galilee, why stand ye gazing up into heaven? this same Jesus, which is taken up from you into heaven, shall so come in like manner as ye have seen him go into heaven.
preachp is offline   Reply With Quote
Old 05-07-2014, 11:05 AM   #10
Those are pricey and a bit overkill IMO
