Anyone use the rear leveling kit?????? - Hemi Truck Club
Old 05-18-2013, 10:54 AM   #1
crash83's Avatar
To lower the rear instead of raising the front?
If so can you show pics please?
crash83 is offline   Reply With Quote
Old 05-18-2013, 12:04 PM   #2
crash83's Avatar
Ok doing some searching here ...and i guess the better question would be how exactly do i go about lowering just the rear for better performance?
Looking at adding the Hellwig bar and trying to get the best handling i can....
Old 05-18-2013, 12:11 PM   #3
Depends if you have a 4G or 3G. New rams you can just trim coil but if its a 3G its not as simple
Old 05-18-2013, 12:13 PM   #4
crash83's Avatar
2004 qc..
The front height is fine but i would like to level out the truck without raising the front.
Looking at lowering shackles but not sure which size to get?2"-3"?
And do i need to add spring clamps?
Old 05-18-2013, 03:15 PM   #5
Stay away from clamps they suck make ride crap as for lowering back to match front would only go about an inch or you end up with the California lean to the rear I hate that look myself makes truck look realy goofy when towing dont know if anyone makes a 1" rear drop shackle but 2-3" yes but will lean back
Old 05-18-2013, 03:20 PM   #6
I had a 2" drop shackle. Be lucky if I got 1.5" out of it.
Old 05-18-2013, 04:12 PM   #7
crash83's Avatar
Pics?
Old 05-18-2013, 04:27 PM   #8
David
ATXHEMI's Avatar
You can remove the over load leafspring as long as you don't tow much or put a lot of weight in the bed. This with the shackles will be pretty much level
Old 05-18-2013, 04:28 PM   #9
I'd have to look I got rid of those an bought a drop kit over a year ago idk if I even have a pic pre drop kit on the site.
Old 05-19-2013, 08:56 AM   #10
crash83's Avatar
I haul a atv from time to time,and i also pull a small trailer[2 atvs] ..
How close will i get just using the shackles?
