AN fittings - Hemi Truck Club
Old 08-30-2017, 05:18 PM   #1
knightmoves's Avatar
AN fittings
As you guys know I swapped out my truck timing cover for a car timing cover. Well every thing worked great! BUT I had to use the truck power steering pressure line. It looks like crap!! I want to run 6AN hose for the pressure line any one know the fitting sizes for the pump and the rack?
Better to be silent and thought a fool than to open your mouth and remove all doubt!!
knightmoves is offline   Reply With Quote
Old 08-30-2017, 05:47 PM   #2
Not sure I would use AN as PS can be around 600-1800psi of pressure easy and even more if there a line blockage or something AN line is not rated for that I don't believe. Have a custom made pressure line made up and be done with it.
Edit: I just saw russel site and they have a ptfe inside lined hose that can take 2800 psi it uses endura finish AN/compression type fittings so it can be done. You will need the correct adapters and what not but do not for any reason use an aluminum fitting they need to be the steel endura at least. I also have no idea the sizes sorry
Old 08-30-2017, 05:48 PM   #3
Man I always screw up fittings. Probably why I have a box of them.. Damn I forgot and I just did this..
With my hydraboost. AN fittings are way too weak. You need a hose made if you want custom.
Old 09-01-2017, 06:45 AM   #4
FASTHEMIRAM05's Avatar
Yoi can do AN fittings they must be steel not aluminum and must have high pressure hoses made. Here local there is a hydraulic supply shop that made all mine and provided the fittings.
Had 2002 4.7 RCSB 14.2
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
Had 2019 QCSB
Have 2020 QCSB
2011 Drag Truck....
