After lift won't stay in alignment - Hemi Truck Club
Old 01-03-2016, 09:09 PM   #1
Hi I got a 6" lift put on my ram 1500 after it was put on I had a wheel alignment the steering wheel was straight , put one evening leaving work a driving off the parking lot just after raining its was a few pot hole now the truck is pulling to the left, I can't believe it would go out of alignment the easy . anyone what could cause these to happen
bedrock is offline   Reply With Quote
Old 01-03-2016, 09:13 PM   #2
Tyler
TYSENUS's Avatar
Check all your tire pressures first.
Mods:
Old 01-04-2016, 04:44 AM   #3
boedacres's Avatar
make shure everything is tight. I had a problem when they went to align it I didn't get the upper ball joints to seat down tight.
Old 01-04-2016, 06:30 AM   #4
I will check it over, if it pop out of alignment that easy if nothing is wrong there , it would go out of alignment something if I had it off road
Old 01-04-2016, 08:21 AM   #5
I would guess something was left loose possibly with the install itself.
Old 01-04-2016, 08:55 AM   #6
Tyler
TYSENUS's Avatar
They don't just pop out of alignment. Most likely that something was left loose as Greg suggested. If everything was installed correctly and tightened properly then it should be fine. Don't forget that, after installing a lift, it's always a good idea to re-torque all your suspension components after a couple days of driving.
Mods:
Old 01-04-2016, 09:29 AM   #7
Question
With that much lift does it have an additional steering stabilizer?
Old 01-04-2016, 04:08 PM   #8
Tyler
TYSENUS's Avatar
Another thing to remember is that if you are running very wide tires that they will pull you around the road with every little dip and curve in the pavement. There is no way around it, it is just the dynamics of running over sized tires. It is part of the reason I got rid of my 22's for 17's, not to mention the cost effectiveness of it.
Mods:
Old 01-04-2016, 09:06 PM   #9
No it doesn't
Old 01-04-2016, 09:34 PM   #10
Something was left looses and when you hit hole it Jared it out of alignment. Most places warranty alignments for so many miles see if they will check it free just say wheel is off and it pulls and you just did it.
