2/4 to 5/7...what to expect during install? - Hemi Truck Club
Old 03-17-2015, 06:19 PM   #1
BottleFedHemi's Avatar
Im dropping my 2004, 2wd, regular cab from 2/4 to 5/7 this week. I purchased lower profile tires, but I'm curious to hear from those who have gone this low. Did you have to modify anything in the engine bay to accommodate the 5 inch drop up front?
Thanks!
BottleFedHemi is offline   Reply With Quote
Old 03-17-2015, 08:26 PM   #2
You will have to cut the factory bump stops off and install diff ones that are smaller or front won't drop the 5"
Rear will need a notch of not already done that low.
Old 03-17-2015, 09:09 PM   #3
Thanks for the input, again! I've got someone helping me with the notch. Everything seems pretty straight forward.
Old 03-17-2015, 09:20 PM   #4
Old 03-17-2015, 10:34 PM   #5
I'm 4/6 an thought about getting that extra inch all the way around just haven't pulled the trigger on it.
Old 03-18-2015, 09:42 AM   #6
Going lower than 4/6 looks good but IMO causes too many problems in my area as a daily driver. Post up the details. I used my front bumps to limit travel and not rub the inner fenders.
Old 03-18-2015, 10:49 AM   #7
Lightbulb
Please post pics when finished
Old 03-18-2015, 07:04 PM   #8
hemiram13's Avatar
2013 RC Express HEMI
Old 03-20-2015, 10:33 AM   #9
Enormous Member
Hugh Jassole's Avatar
I did 5/7. Spindles and cut 1/2 a coil up front. Flip kit mounted in the upper shackle holes in the rear. It desperately needs a notch out back. The front was/is fine. I cut the old bump stops and mounts off and went with the pancake type up front. Used the same kind in the rear. But like I said, it needs a notch
My other truck is an R/T
Old 03-25-2015, 08:41 PM   #10
Sorry for the delay. Here's the finished product. Not sure how close I came to the full 5 inches up front, but Im pretty sure we got the 7 out back. LMK what y'all think...
