Trans cooler - Hemi Truck Club
Old 01-17-2015, 05:10 PM   #1
Trans cooler
Hello I have a question . Where is the trans cooler restrictor located I dint have constant cooler flow until the trans is warm
I was told that's it is the cooler and other people tell me its in the trans.
I would appreciate the infp
2003 1500
5.7
45rfe trans
Thanks for your help
ken3520 is offline   Reply With Quote
Old 01-17-2015, 06:02 PM   #2
I'm pretty sure it is in the trans (545RE). I don't remember seeing anything in the cooler.
Old 01-17-2015, 06:04 PM   #3
I have the 5 speed 45RFE
Old 01-17-2015, 06:16 PM   #4
Yes, referred too as a 545RE. The difference between the two is in the electronics. Look at the data plate on the driver side about mid way down the case.
Old 01-23-2015, 09:24 AM   #5
The previous generation transmissions had a check ball inside the transmission by the cooler line fitting...not sure about the 545RFE. Here's the service manual for it, it might have what you're looking for:
http://www.hotrodlane.cc/New%20HEMI%...mi%20trans.pdf
2006 Ram 1500 QC 4x4 5.7 Hemi: 132,xxx miles
Mods: 1-ton trans cooler | 3" FM 40 single exhaust
89gtcs is offline   Reply With Quote
Old 01-23-2015, 11:18 AM   #6
Don't believe there is one. You have the over pressure blow off inside trans pan and the the solenoid for the cooler if there is one I forget.
