Questions regarding my 2004 dodge ram - Hemi Truck Club
Old 09-20-2013, 12:04 AM   #1
Hey Guys,
So I've been noticing a couple of things with my truck recently that make me wonder whats wrong with it. First when I first start driving in the mornings and I'm going from about 15-25 mph i feel like the truck pulls back then it continues to accelerate and from then on the truck is fine. Its not a big pull but I notice it and it mostly only happens when the truck has been sitting for a couple of hours. Second, Ive been noticing that motor oil has been disappearing from the truck. Last oil change it was down about 2 quarts and today i checked the oil and the dipstick read about an inch down from where its should be. I haven't noticed any smell but the motor cap does have a chocolatey color. So where is the oil going? Third, I wanna change the gear oil but i don't remember how much to get. I have the Mag-Hytec cover with 4.56 gears and last time I changed it I bought royal Purple 75w-90. I want to know what gear oil would be better and if I would need the additive in it. Sorry for all the questions guys.
Surge171 is offline   Reply With Quote
Old 09-20-2013, 04:46 AM   #2
If its burning it you would likely see smoke out the pipe
Also check your coolant and see if oil is possibly mixing
Old 09-20-2013, 06:58 AM   #3
TooCool's Avatar
Stock rear end cover your looking at about 2 1/2 qts. I believe the Mag Hytec increase's capacity. (you may want to look up how much) Some rear gear oil's say they don't require the addative. I use Amsol and i added the additive anyway.
Old 09-20-2013, 08:06 AM   #4
What differential are you using? Some don't require additives. I would replace the PVC valve and check the spark plugs to see how they look.
Old 09-20-2013, 09:21 AM   #5
Gary
leadfoot's Avatar
My truck was using a quart of oil since new. At about 50,000 it was up 2 quarts every oil change. No leaks and no smoke . I noticed more usage when I switched to mobil one synthetic.
Old ride
03 ram quad cab hemi
New ride
2013 Ram Crew Cab Sport
No Mods
Old 09-21-2013, 06:21 PM   #6
i have the detroit truetrac and i havent seen any smoke from the tailpipes. I checked the coolant too and no oil.
Old 09-22-2013, 04:06 AM   #7
How many miles do you have on your truck?
Old 09-22-2013, 08:01 AM   #8
The DDT doesn't use modifier. It uses gears instead of clutches.
Old 09-22-2013, 10:43 AM   #9
my truck has 125k miles on it i just recently changed the spark plugs last year ill look later today see how they look
Old 09-22-2013, 07:57 PM   #10
As much as I hate to say it....... Most V8 engines do burn a little oil with that many miles.
When was the last time the throttle body was taken off and cleaned?
