Low heat - Hemi Truck Club
Like Tree3Likes
  • 1 Post By SUPER BEE
  • 2 Post By charged392
Old 12-15-2018, 10:18 AM   #1
Low heat
Just started recently having lukewarm heat. Heat gauge was a little low so I replaced the tstat and no difference. Heat is not as hot as before, if I run the fan speed on low it gets fairly hot but when i increase the fan speed the heat will turn to blowing cool. I turn it back to low speed and after a bit its warm. Any ideas on what I should check first ?
_________________________
Old 12-15-2018, 01:46 PM   #2
Make sure you have very hot coolant in both of the heater core hoses. I would also check your blend door, if it's broke or stuck in the fresh air mode, you will be getting cold air mixed with the heated air.
bada44 likes this.
Old 12-16-2018, 06:39 AM   #3
Check hoses for heat in and out like stated. If you have it on low and not high and have a little heat that’s most likely a restricted heater core or low coolant level/air
bada44 and SUPER BEE like this.
