Hemi brake Hydroboost Setup Conversion Questions - Hemi Truck Club
Like Tree1Likes
Old 04-17-2014, 07:33 AM   #1
rowdog_14's Avatar
I am looking to do a Hydroboost setup for my truck. I see Weedahoe has done it but I was seeing if anyone else has crossed over to it?
What are the Pros/Cons of this Setup?
This is my Pro/Con list
Pro:
-Better braking power
-More room in the engine bay
-Getting rid of the big brake booster
Cons:
-More complicated setup
-Stopping power without the truck running, but from what I have seen it does have an emergency feature.
Current upgrades
- Jet 180 - Mopar Gauges- Class IV hitch - Borla Cat-Back - 4ga Dynamic Grounding - 10ga TB grounding - Sonnax trans line pressure - BBK Shorties#4009 - TheFastMan 85mm Throttle Body - SCT HemiFever Custom Tune - Magnaflow y-pipe #10748 - Doug's cutout #H1131 - K&N Intake 57-1533 - Comp 268 Cam -6.1 springs, pushrods- Summit UD Pulley
Upgrades to come and I am done:
1.Edge Torque Converter (2400-2600) 2. Race Ready Electric cutout 3. Detroit True Trac 4. Motive 4.10 gears 5. McGaughys shackles
rowdog_14 is offline   Reply With Quote
Old 04-17-2014, 03:44 PM   #2
This is a good mod IMO. I'll have to start watching for bits and pieces..
Old 04-17-2014, 04:08 PM   #3
Matt
MANual_puller's Avatar
The ONLY bad thing about this mod I can think of is that if you were to ever blow a power steering line(very rare) you would lose your brake booster too since they would be using common fluid/pump. You'd still have brakes but you'd really have to stand on it. Doing this mod removes places to develop vacuum leaks and makes plug changes easier. It's a reliable system, not that the vacuum assist isn't, but I'm in the camp that hydraulic assist is actually a simpler system once you figure it out than vacuum assist.
Old 04-17-2014, 04:12 PM   #4
Gary
leadfoot's Avatar
I have it on my wifes gmc truck. Love the setup
Old ride
03 ram quad cab hemi
New ride
2013 Ram Crew Cab Sport
No Mods
Old 04-17-2014, 05:12 PM   #5
Old 04-17-2014, 08:29 PM   #6
Truck of the year 2014
Belgiquebasterd's Avatar
I've read that there is some kind of safety feature in the system that gives you pressure for an emergency stop if it happens. A snapped v belt would have te same effect too.
On the other hand if a vacuum line comes of on the vacuum booster you got the same situation. I'm running hydroboost and is one of the best mods to do IMO.
Old 04-17-2014, 08:36 PM   #7
Matt
there might be a check valve so you've got psi assist from the line for one stop, idk. The brakes will still work, just gotta do some squats lol
Old 04-18-2014, 12:13 AM   #8
Did a bit of research, seems to me that hydroboost is 'safer' than a vacuumbooster. If you lose vacuum for some reason (popped hose, exploding intake manifold, you know the regular hemi stuff) you would lose power brakes.
Hydroboost systems have an accumulator (checked the manual and there is mention of an accumulator in a dodge hydroboost system), apparantly the accumulator gives you 2 or 3 power brakes.
Bit of info I found on the net:
Source:
http://="http://books.google.be/book...lator&f=false"
Old 04-18-2014, 05:49 AM   #9
Yes hydro boost has an accumulator for 2 maybe 3 stops. Vacuum boosters have the same feature there is a check valve that stores the vacuum for 2 maybe 3 stops.
Hydro boost Deff gives you more stopping power pressure wise thou
Old 04-18-2014, 09:57 AM   #10
I need to start gathering parts apparently. This is a good mod IMO.
