Help ID this hose - Hemi Truck Club
Old 08-22-2016, 01:35 PM   #1
Help ID this hose
Could someone tell me where this small hose hooks up ?
_________________________
Old 08-22-2016, 02:48 PM   #2
That looks like the purge valve hose. It connects right behind the brake booster hose. They are the only two vacuum lines used.
Old 08-22-2016, 02:57 PM   #3
Ok i will go take a look. I did disconnect the big brake booster hose when i installed new ngk plugs today
Old 08-22-2016, 03:25 PM   #4
That is the intake manifold end of the evap purge valve. There should be a nipple directly behind the throttle body drivers side.
Old 08-22-2016, 04:45 PM   #5
edit:
Ok went back out and it was the line coming from the purge valve. There is a bigger hose that comes from the brake booster and goes to the intake behind the throttle body. This hose slips on a port directly behind the bigger hose, i just couldnt see it as the view was blocked by the bigger hose. Just has to feel around behind it and there it was
Thanks guys
Old 08-22-2016, 04:56 PM   #6
It's right behind where the booster connects. Maybe hidden by the boost hose. Use your hand and feel around behind the booster hose. It's there believe me.... lol
Old 08-22-2016, 05:00 PM   #7
Yes it was thanks
Old 08-22-2016, 07:31 PM   #8
Lol yep called that one
Old 08-23-2016, 04:08 AM   #9
Thanks
