Fuel problems.. - Hemi Truck Club
Old 09-23-2015, 07:43 PM   #1
Fuel problems..
Truck acts like its starving for fuel. Starts and idles for about 2 seconds then you smell gas. Have fuel pressure up to at least the fuel rail. Already replaced throttle body, evap purge valve, idle air control, cam sensor and crank sensor, ECM. No codes.
Clones87 is offline   Reply With Quote
Old 09-23-2015, 07:46 PM   #2
Smell raw fuel leaking or thru exhaust?
Old 09-23-2015, 07:47 PM   #3
Through exhaust
Old 09-23-2015, 07:50 PM   #4
If you smell fuel then it's likely not stArving for fuel. Do you have access to a scanner? Also if you drive it and floor the gas does it just have no power or does it sound likes it popping?
Old 09-23-2015, 07:54 PM   #5
Just idles about 5-10 seconds. Already been scanned no problems.
Old 09-23-2015, 07:55 PM   #6
Is this a 4.7?
Old 09-23-2015, 07:58 PM   #7
5.7
Old 09-23-2015, 07:58 PM   #8
Oh so it won't run long at all then shuts off. There's something wrong here and a scanner is the only way to figure this out from this point I believe. Not
For
Pulling codes but making sure all sensors and what not are ready corectly.
Old 09-23-2015, 08:00 PM   #9
When we had it scanned all the sensors were reading correctly and showed spark advance was fine
Old 09-23-2015, 08:03 PM   #10
This is weird then. If all sensors are reading good but it still won't run and the little it does run its super rich. What is the actual fuel pressure at the rail?
