Front Wheel hub/bearing replacement - Hemi Truck Club
Old 04-09-2018, 10:48 AM   #1
Hey guys. so, the fron wheel bearing is grinding. Needs to be replaced. Just bought a new one. My question is, Is there a way to remove the bearing without removing the axle? It's such a PITA getting that damn axle in and out. Or, is there an easier way to remove the axle? I'll be doing this in the parking lot, on jackstands. Thanks in advance!
RumbleBee2286 is offline   Reply With Quote
Old 04-09-2018, 11:22 AM   #2
xtremwlr's Avatar
Sounds like you have a 4wd. Mine is 2wd so I didn't have to deal with the front axles. Sorry I can't be of more help!
Old 04-09-2018, 12:38 PM   #3
Enormous Member
Hugh Jassole's Avatar
unbolting the upper and lower ball joint and remove the spindle instead ?
My other truck is an R/T
Old 04-09-2018, 08:37 PM   #4
Leave the axle in the truck. You will need to remove the big axle nut first then the caliper and bracket as a whole hang it out of the way. Then dissconnect the speed sensor wire. After that if it’s 4x4 1500 should be 3 15mm bolts or if it’s 2500 4x4 there is 4 15 or 18 mm nuts. Then a little bit of hammer persuasion and it’s out.
Old 04-10-2018, 05:02 AM   #5
Leave the axle in the truck. You will need to remove the big axle nut first then the caliper and bracket as a whole hang it out of the way. Then dissconnect the speed sensor wire. After that if itís 4x4 1500 should be 3 15mm bolts or if itís 2500 4x4 there is 4 15 or 18 mm nuts. Then a little bit of hammer persuasion and itís out.
JUst did mine and this is how i did it. You may need to push in on the axle a bit for clearance.
2003 - Air Raid CAI, Magnaflow, Hedman Shorties, SS nerfbars, superchips tuner, LED Tube headlights, 32Ē light bar, gator trifold bed cover.
_________________________
Old 04-10-2018, 09:13 PM   #6
Gold-Member
kcd1369's Avatar
Did both of mine a few years ago. Its a PITA but not all that hard.
good luck.
