Few Crazy small issues...Bad Computer??? - Hemi Truck Club
Old 06-09-2014, 12:17 PM   #1
rowdog_14's Avatar
So a while back I had an issue with my seat belt light coming on and my radio turning off but still being able to remove cd and tell time. I do not remember when this started happening but I think It might have been when I stacked SCT/SC.
Well now I have been running just SCT and this last week or two when I am driving and mainly when I hit a bump the happens. I checked the computer to make sure it was fully attached to the firewall and side rail, but it still seems to happen. I check the seat belt connection and the radio connection and nothing felt loose. I have disconnected my battery and sometimes that works, sometimes it does not.
These are the current issues I have:
1. The seat belt lock feature does not work and the seat belt will retract even when braking.
2. The seat belt light will come on but there will never be a chime.
3. Radio will not turn on but will allow you to insert and eject disc and also check the time.
4. The rear Pass light do not come on when you turn your headlights on but will work with the brakes, backup, and the turn.
Has anyone seen or heard of this issue before????? I really do think the stack killed me but I can not confirm when this all started
Current upgrades
- Jet 180 - Mopar Gauges- Class IV hitch - Borla Cat-Back - 4ga Dynamic Grounding - 10ga TB grounding - Sonnax trans line pressure - BBK Shorties#4009 - TheFastMan 85mm Throttle Body - SCT HemiFever Custom Tune - Magnaflow y-pipe #10748 - Doug's cutout #H1131 - K&N Intake 57-1533 - Comp 268 Cam -6.1 springs, pushrods- Summit UD Pulley
Upgrades to come and I am done:
1.Edge Torque Converter (2400-2600) 2. Race Ready Electric cutout 3. Detroit True Trac 4. Motive 4.10 gears 5. McGaughys shackles
rowdog_14 is offline   Reply With Quote
Old 06-09-2014, 01:43 PM   #2
I think you have a few issues here that all happened around same time.
The radios fail a lot just like that here in Florida takes cd and tells time but nothing else.
The seatbelt chimes go bad a lot too they are built into cluster on your truck I believe.
The retractors also get stuck so you can't lean forward periodically for some reason or another the retention clip fatigues and works more than it should
As for the lights that may be anything would need to be there to pinpoint that guy have not run into any light issues yet with rams other than the 2003-2005 tailight boards
Old 06-09-2014, 02:09 PM   #3
rowdog_14's Avatar
The only thing is that all of these things happen at once as soon as I hit a bump. Everything will be working fine and small bump, functionality gone on the radio, seat belt light comes on, and you can hear the seat belt lock unlock. As far as the taillight I think that might have to do with a bad board because I have had a leak in that bad boy for a long time now and I noticed it not working yesterday when my son turn on my headlights.
Current upgrades
Old 06-09-2014, 02:28 PM   #4
Adam
04hemisportedt's Avatar
Not to jack your thread but what are the symptoms for a bad taillight board? I keep getting a light out ding when the lights are on, goes away with brakes pressed, but they're all new bulbs
AEM Brute Force Intake
Custom Painted Headlights
Custom Plastidip Wheels
Spike Lug Nut Covers
Debadged
3" Exhaust w/ AT3030XL
UnderCover Tonneau Cover
Rhino Lining & Under Spray
Bully Dog Triple Dog Tuner
Old 06-09-2014, 03:11 PM   #5
rowdog_14's Avatar
I know the boards say let and right but to my knowledge the connection are still the same. You could probably swap the board from the pass side to the drivers side to see if you still have the problem. I am actually going to do that as soon as I get home.
Current upgrades
Old 06-09-2014, 06:06 PM   #6
I'm so torn to try stacking. I don't wanna deal with weird PCM gremlins more than I already have to. But man I don't want stock shift points!
Old 06-09-2014, 06:24 PM   #7
rowdog_14's Avatar
Yeah I fully understand ...personally I would not do it again. As great as the shift points were, it was not worth the headache, hassle, worries, and other possible problems . I will take my stock shift points all day over stacking
Current upgrades
Old 06-09-2014, 06:28 PM   #8
Adam
But if I don't know which board(s) it is, switching them wouldn't get me anywhere...correct?
Debadged
Old 06-09-2014, 06:34 PM   #9
rowdog_14's Avatar
Sorry yes. I mixed my way of diagnosing mine, lol. If you have a buddy with a dodge ram see if he will let you borrow a board.
Current upgrades
Old 06-09-2014, 08:18 PM   #10
Make sure and check all the grounds inside the cab along the foot kick panels on the sides the bump sounds like a loose wire issue
